rolled my A mod out yesterday
Discussion in 'The Hokey Ass Message Board' started by sko_ford, Mar 30, 2008.
  1. sko_ford
    sko_ford
    heres the pics from yesterday of the car as a true roller. axles fully mounted and the body tacked back together with the start of the sub floor in. i do think i may lower the back of the body just a bit since there is just a bit of fame showing under that back corner.
    it is the first time in a year that ive had it out and together. and now things should roll together i hope
  2. CRH
    CRH
    from Utah
    Good job! Another major phase completed, and it probably feels good!
  3. moses
    moses
    looooookn goooood now back to work...jeffrey
  4. HOT ROD DAVE
    HOT ROD DAVE
  5. 31Rodder
    31Rodder
    Looks like things are coming along good.. I see you said that you might lower the back down, how about raising the front of the cowl the body has quite a rake to it?
  6. sko_ford
    sko_ford
    thanks guys. more work to go but is coming a long. on raising it up then i wouldn't be able to step over and in as easily and i like the rake so I'm just going to drop it enough to cover the frame
  7. sko_ford
    sko_ford
    so i blew it apart last night so i can start fixing and welding the bits and peices that i couldnt with every thing in the way tonight
  8. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    looks almost like a hot rod- :D nice work
  9. bigken
    bigken
    Congrats on the milestone.
  10. sko_ford
    sko_ford
    thanks i'm shootting for hot rod insted of 400 cid wheel barrow like my father-in-law called it
  11. raven
    raven
    I like that frame.
    r
