Time to start the roadster, which crossmember?
Discussion in 'The Hokey Ass Message Board' started by Lucky77, Apr 2, 2008.
  1. Lucky77
    Lucky77
    Okay, I've been driving my sedan for three weeks now and I love it. Its by no means done but I've got the itch to start this evil process all over again. So far I have a complete 30 roadster, a 1946 p***enger car rear axle, 46 front backing plates, a stock A front axle that I will have dropped 3.5"-4". I have two sets of 37-41 round back spindles, a 47 p***enger car front spring I planned on using on the rear. I have seven 16" 1935 wires as well as one 16" 40 steelie and two 15" Mercury steelies. Not sure which style of wheel I'll go with. I also have a 1946 59AB flattie that Im not sure is any good but its complete and I can use it for mock up. I'm going to follow the basic plans in the Bishop/Tardel book but I don't want to use a32 K member. What are my other options as I plan on using the torque tube and a 3 speed top loader.
  2. fab32
    fab32
    Try fitting a F1 crossmember and pedal ***y. Some here have tried it and made it work. I believe a search will turn up something. And NO the crossmsmber in my '48 F1 is NOT available. Now get off the computer and get ready to meet us for lunch.
  3. MBL
    MBL
    F1 is the way to go. I have it in my T roadster using a Model A frame. Really EASY, and cheap to find. They are all over.
    Tim
    MBL
  4. Lucky77
    Lucky77
    What about the flathead and 3 speed sitting between its fenders?:D
  5. SUHRsc
    SUHRsc
    if you get a transmission mount from anything 34-48 it'll have ears off the sides
    then all you need to do is find a way to have something for them to sit on
    get your waterpumps on and make your front mounts....then jack the motor/trans up till you figure where it needs to be and then fill the void with some sort of mount
    pretty straight forward
    seems you have almost enough to build the car pretty quick
    you might want to consider still using the A spring and adding mounts onto the V8 rear
    also keep in mind that the 46 rear is pretty wide so be careful who drops your axle and make sure they dont thin it down too much to where your front end is ALOT thinner then the back
    heres my friend Rogers '31 roadster
  6. Lucky77
    Lucky77
    Thanks Zach, your friend's roadster is pretty close to what I'm looking for. What is the reason for using the A rear spring? I was going to build the car out of the ch***is sitting on the table, then just lift the body off the complete car and set it on the new frame when its done. If I can avoid dismantling the complete ch***is I'd like to do that. Suppose I can always get an A rear spring somewhere.
  7. HOT ROD DAVE
    HOT ROD DAVE
    im going to save this thread as its getting real interesting, keep posting guys, you have my interest sparked
  8. SUHRsc
    SUHRsc
    i just think it gives a nice stance with the A spring in its stock location, Zing the frame like in the Tardel book (what roger did)
    saves having to make a frame longer extending over the rear to match the 46 locations
    his car is Z'd the thickness of the frame and then has a dropped axle
    he still has room to have a working rumble seat back there and i think it sits perfect
  9. GatorO'dell
    GatorO'dell
    O.K. guys
    In 9 days I will be home from a 15 month trip to Iraq and I am going to be building the same car. I want to se pictures and alot of them! I am going to be using a F1 crossmember and pedals "this is the big part I wanna see" Also I beg you to post good pics of how you shorten your torq tube and shaft. You may just be my new best friend. Hell I might just stop looking at **** to follow this thread!
  10. MBL
    MBL
  11. fab32
    fab32
    What flathead?................. what 3 speed?.................. I don't see any flathead and 3 spd. You must be halucinating........ probably too much CO from that open exhaust on the 2dr. Shame............and I always thought you had your head on straight.:rolleyes::D
    flathead.........3spd............these young guys are dreamers. Have any idea how much I could get on Ebay for that stuff. Besides I'm going to fix that 'ol truck up someday.;)
    Frank
  12. Ha, just ran in to search for new A front crossmembers, and this thread popped up 1st...I need the one that is lowered 2 inches over stock. Need one if you all know where I can get it quick. Putting it in a 32 frame for a customer, need it fast while we have motor pulled. Thanks...
    Here is a pic of an F-1 in an A frame....I love em, cheap, and look right at home.
    I may see if I can squeeze one in a pinched 32 frame for another customer, we'll see. May be a little short, not sure yet. Good luck!
  13. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    I agree with Zach and keep the original Model A rear cross member. The car will sit pretty close to perfect and you'll have the clearence if you ever want to add a quickchange somewhere down the road.
  14. hatch
    hatch
    from house
    Scott...better hurry and get buildin....you're gonna need something to drive next time I head that way....I'm takin the c/dan!!:)
  15. Kiwifruit
    Kiwifruit
    sorry for the silly question, but what year(s) F1 X-member?
    thanks.
  16. HHRdave
    HHRdave
    from So Cal
    If you can't find an F1 crossmember, you can always make one. I've seen guys use square tubing and some 1/4 plate. Just make sure you have that dual bolt rear trans mount and some bushings. I wish I could find the pic.
  17. Lucky77
    Lucky77
    Thanks for all the advice guys and the link MBL. I was looking for a crossmember that the end of the torque tube would bolt to like the 32 K member. If you just use a mount like the F1 do you need to sure up the torqu tube in some way or di you have to convert to an open drive?
  18. Lucky77
    Lucky77
    No problem, just watch it when you take the car for a drive. A really strange thing happens if you turn the wheel and give it some gas; you wind up facing the opposite way you were traveling. Weird, I've never owned a car that will do that:D
  19. MBL
    MBL
    You keep the torque tube. You mount the ****** to the crossmember and the front u-joint fits over the drive shaft. The external tube bell portion fits over the area that the U-joint is housed in. Then a collar is bolted to hold the bell portion up against the ******.
    Take a close look at the first pic in the link I posted.
    TIm
    MBL
