HELP With ANY knowledge of 262 and 350 chev engines
Discussion in 'The Hokey Ass Message Board' started by Zombiefink, Apr 3, 2008.
  1. Hey there,
    I've been doing my research, and its not going all too well when it gets down to the bottom of it..
    Anyways, the new law over here in Australia forbids the use of a v8 on your P-Plates.
    So as i said, my research is missing some pieces...
    I read on a website that a Chevrolet 262v6 4.3l
    Is the same as a 350 chev, just without the two extra cylinders!
    Also i read that a 262 will bolt up to a 350 chev trans...
    All in all im planning on putting a 262 into a car that has a 350 chev trans, and 350 chev engine mounts..
    Any help on making this work would be greatly appreciated!
    Thanks in advance,
    Jackson
  2. tomslik
    tomslik
    mounts will be in a different spot on the frame but,depending on which 4.3 you're using,brackets and such may or may not work but will prolly be close enough to make work.
    flywheel/flexplate are gonna be different from the old 2 piece rear main small block chevy...
  3. ah ok, So a 262 is actually alot like a 350?
    The person selling the car has a 350 chev in it, so im thinking of just buying the transmission...
    Should i buy the transmission or not?
    Coz i wanna hook a 262 up to the car..
    Also, would you be able to tell me what i will have to do to put a 262 instead of a 350 in....like mods etc..
  4. cruisinkruty
    cruisinkruty
    It will all bolt up and give ya alot of room up front :) Its funny when your buildin a 200,229 or 262 because everything is sbc except yer shy two holes.I had a pretty strong 229 I built for a malibu wagon. I really liked that 229. It was .030 over,Comp cams 260 series cam,double roller chain and gear,melling HV pump,I did a wee bit a work on the heads. 3 angle valve job back cut intake valves bronze guides polished and equalized chambers gasket matched the ports to the manifold. It was an amazing efficient little V6. I wonder why GM developed the damn Buick 231 V6 and dumped the 229 chevy. Just my 2 cents worth.:rolleyes:
  5. tomslik
    tomslik
    i think we'd all be better off knowing what your plans are.
    what's it going in?
    carb or fuel injection, etc....
  6. Cheapest for my money of course, see this may sound stupid, but i know alot about my cars, but not too much about engine parts...
    So i'd say just carbs, not fuel injection
    But yeah, Im buying a Chev off someone which currently has a 350 chev in it...
    My plans are to put a 262 6 cylinder chev in the car, and i was wondering if i need new engine mounts, trans, tail shaft, etc.
  7. what is a p-plate if the car is already inspected and on the road why change
  8. Its got a 350 chev in it, and thanks to the new laws, We're only allowed a 6 cylinder on our P-Plates. :(
  9. The bellhousing pattern and flywheel depth in the bellhousing are the same between 350 and 4.3 Chevys. The motor mounts will be around 4 3/8"
    (112mm) closer to the bellhousing face on the 4.3. The motor mount pattern on the side of the block is the same. Most 4.3 engines don't have provisions to use a mechanical fuel pump. You can use the cylinder heads from a 229" v-6 on a 4.3 if you want to get away from the vortec intake port design.
    There were a few hot rod v-6 engines that were used in ASA stock car racing, had some neat parts that never made it to the GM showroom floor.
    The accessories on the front of the engine also bolt up the same as v-8 Chevys.
  10. Tudor
    Tudor
    from GA
    V-8s have been outlawed? I'd shoot myself.
  11. Thanks for all the info guys!
    But my main question still hasnt been answered....Would a 262 fit where a 350 has been?
    More info:
    1. Would a 262 bolt up to the gear box where a 350 has been?
    2. Would i need to get new engine mounts for the 262 to replace where the 350 has been?
    3. Would i need to get any new extras for the 262? eg, New Brakes, New wiring...etc
    4. List anything i'll need to change to fit the 262 nicley where the 350 has been.
    Thanks in advance ;)
  12. the 4.3 V-6 and the 350 V-8 have the same bellhousing bolt pattern , so the transmission will bolt up.....however, depending on what years the ****** and engine are you may have to switch flywheel / flexplate
    yes, the 4.3 is basically a 350 with 2 cylinders removed....so motor mounts will need to be moved back....the exhaust .depending on the manifolds would need some work to connect
    wring..i think all 4.3's had an HEI distributor....if the 350 didn't you would need to make a few minor changes
  13. 53sled
    53sled
    from KCMO
    WTF is a P-Plate? P***enger car plates?
    Yes it will fit.
    But in america, we are ususally trying to put a 350 where a 4.3 was. :)
  14. Tudor
    Tudor
    from GA
    262 straight 6 or 4.3 V 6 ?
    please explain what a P-plate is and why have V-8's been outlawed
  15. P-Plates are what you're on on your first 5 years of your licence...
    P stands for Provisional.
    Reason V8's have been out lawed is because ****heads with their modern day cars use to do street racing, and posted it on the internet, eventually the dumb***es kept crashing and killing themselves, So then they made the new law, no higher than v6
  16. tomslik
    tomslik
    see if you can find a 4.3 from an early, as in about 85-86 astro/safari van.
    they had carbs....87 started tbi stuff...
    not that you can't use the later 4.3's, it's just that all the stuff would be there that you'd need for a carb setup....
    things may be different in oz, so....
  17. Wild Turkey
    Wild Turkey
    http://www.s10forum.com/forum/262ci-forum-4-3/
    Here's a forum that's just about the 263 cid/4.3 90 degree v-6/
    Do a search and you might find what you're looking for.
    You might also try the V-8 section of that board -- they're putting a 350 in where a 263 was, you'd just have to do the opposite.
  18. Brad54
    Brad54
    from Atl Ga
    Fight the man! Build a 3.8L Turbo Buick, and wipe their eye with it.
    -Brad
  19. Im actually planning on making the car more of a cruiser, rather than a turbocharged streeter..
    Also, I read on other forums that a 262 is a truck motor, i thought that was the 292?
  20. old dirt tracker
    old dirt tracker
    from phoenix
    the lesson here is if you abuse something you stand to lose it. the actions of a few have affected the rights of many.
  21. enjenjo
    enjenjo
    from swanton oh
    !. Yes
    2. No. Just relocate the mount on the frame 4.3" back
    3. No
    4. Exhaust head pipes and new radiator hoses.
    A Chevy V6 is just a V8 with two cylinders missing.
