frost plugs
Discussion in 'The Hokey Ass Message Board' started by jimbos52, Apr 13, 2008.
  1. jimbos52
    jimbos52
    from boonies
    Today while working on my 87 toyota with an 85 305sbc My dumb*** managed to push a frost plug right into the motor . the frost plug is right above the driver side motor mount all of 3/4" max from the block to the mount .
    1) can it stay in the block?
    2) will it cause a blockage?
    3) how would I get it out?
    thanks for any help and let the flaming begin
  2. rodknocker
    rodknocker
    I wouldn't leave it in there,how bad would it be to just loosen that motor mount and jack the engine up enough to grab it with some channel locks.
  3. jimbos52
    jimbos52
    from boonies
    thats what I was thinking but i was just hoping my luck didnt seriously kick me in the *** . I was attempting to make the anual april 20th mud runs .
  4. randydupree
    randydupree
    from archer fl
    don't worry about it,theres hundreds of engines out there with frosy plugs in the block.
    hell,most shops just bang them in when they replace them.
  5. oilslinger53
    oilslinger53
    from covina CA
    maybe yuo could screw a self drilling sheet metal screw into it so you'll have something to grab?
  6. Yep- FAHGITABOUDIT...
  7. jimbos52
    jimbos52
    from boonies
    when i pushed it in , i really pushed it in haha i was feeling around the very minimal area i could reach and i couldnt feel it ill try a magnet and a self tapper if i get ahold of it thanks for the help everyone
  8. hoarder1212
    hoarder1212
    Try to get to it with channel locks. If you can't then drive it down out of the way and put in a new one!
  9. David Chandler
    David Chandler
    Fiddle around with it until you can get some vicegrips locked on to it, then twist it out. Normally you drive them in and pry them out to change them. Expect to put in a new replacement too.
  10. jimbos52
    jimbos52
    from boonies
    thanks for the input everyone
