DOM tubing supplier?
Discussion in 'The Hokey Ass Message Board' started by not so hotrod, Apr 15, 2008.
  1. not so hotrod
    not so hotrod
    from MA
    Anyone know of a DOM tubing supplier in the North East?
    I will be constructing a tie rod and drag link using tie rod ends with a 20x1.5 thread. So about .730" ID (18.5mm) with a safe enough wall thickness.
    What wall thickness do you guys out there run? Ive read that .187" is pretty good.
    thanks dudes
    Dan
  2. noboD
    noboD
    If you only need a short { less then 6 ft.} how about McMaster-Carr?
  3. not so hotrod
    not so hotrod
    from MA
    All that I could see was 3ft length in that diameter.
  4. Goztrider
    Goztrider
    from Tulsa, OK
  5. mg98ta
    mg98ta
    from Denton, NC
    Check out A.E.D. motorsports. They have anykind of d.o.m. you can think of. Just google them. I've ordered chromemoly from them in the past and they have good prices to and they'll cut to length if needed.
  6. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    First off why are you using 20 mmx1.5? God damn commie stuff! Go with a standard rod end that is 3/4-20 and then buy a weld in adaptor from Speedway or Ch***is Works and weld it into a piece of 1 inchx .058 4130 and have a link that is strong and doesn't weight 15 lbs. Probably get all the parts for less than the 20mmx1.5 RH and LH taps!
    Rex
  7. tcoupekyle
    tcoupekyle
    I got mine at fastenal
  8. boldventure
    boldventure
    Check ThomasNet.com. You can search for DOM mild steel tubing in your area and lots of places will show up.
