Anybody try these dollys from Harbor Freight?
Discussion in 'The Hokey Ass Message Board' started by montclaire, Apr 16, 2008.
  1. montclaire
    montclaire
    My new project has two flats and two bare rims, so I'll need some dollys to get it around the shop. I know HF has the vehicle dollys, but I'm on a budget. I spotted these moving dollys, rated to 1000 lbs, and only $15.99 each. They're 18 x 12, so I figure they should work. Waste of time?
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93888
  2. zman
    zman
    from Garner, NC
    I use the larger ones like that for engines, transmissions, and differentials all the time. I don't know if they would support much more than a Model A or something like that for long...
  3. Aman
    Aman
    from Texas
    I have a couple that work great. One of the few things that HF has that is worth the money.
    Edit: I had a 350 on one for a couple years in the shop. Still have it.
  4. Crankhole
    Crankhole
    they might work if you add another plank across the top to distribute the weight. I had a complete flathead on one for about a year and it finally snapped. The bolts holding the casters on aren't too stout either.
  5. SaltCityCustoms
    SaltCityCustoms
    I use those for moving bodies around, but a whole car! I hope its a light one.
  6. montclaire
    montclaire
    Here's what they have to hold up:http://www.jalopyjournal.com/forum/showthread.php?p=2742825#post2742825
    The back end should not be a problem, but the engine and trans are still in it so the front might be a little heavy.
  7. 35Chevy.com
    35Chevy.com
    from New Jersey
    I purchased 6 of them a few weeks ago for $10.00 each
    their rated for 1000 lbs I put the car up on them and
    now I'm able to push it all over the garage
    Gary
  8. montclaire
    montclaire
    Gary, you sold me, thanks
  9. They keep running out of them at the HF near me!
  10. fordcragar
    fordcragar
    from Yakima WA.
  11. fordcragar,
    There have been lots of reports of the catsters breaking easiley on those- keep your toes out from under 'em!
  12. arpedersen
    arpedersen
    from Idaho
    We run some heavy stuff around on those things, but I've never seen anything over 400 pounds. It was a big crate, and we used one in the middle. It held up well. but I wouldn't get under the car if it were on that thing.
  13. fordcragar
    fordcragar
    from Yakima WA.
    Thanks, but where have you seen the reports?
    I've had these for years and never had a problem, they do have steel wheels, but like everything else at Harbor Freight you probably wouldn't want to trust it to much. I put one under each wheel and roll a complete 3500 pound car around the garage.
    Just got a Harbor Freight flyer in the mail, with these on sale.
  14. Wildfire
    Wildfire
    Got two of those under the rear tires and a larger one under the front I-beam. The whole car is on them - granted, it is a model A and probably doesn't weight 1200 lb right now, but it is great.
  15. HOT ROD DAVE
    HOT ROD DAVE
  16. JimA
    JimA
    I broke those wood ones moving a '32 BODY! They were brand new. I have had no trouble with the black metal ones. Jim
  17. Don Lyon
    Don Lyon
    I've had the HF dollies for years. Had a 46 coupe on 'em(whole car, not pieces). Also had a 37 Chev coupe frame / body ONLY on 'em, never had a problem.
  18. 31HotRodLincoln
    31HotRodLincoln
    I built my own for my engine . The 4" casters were 20 bucks.
    and used 2"x6" lumber, bolted together with carriage bolts.
    It holds the 900#lb engine no problem
  19. Black Primer
    Black Primer
    35 Chevy.com, is that an adjustable height body dolly you have? Would love to see more pictures of it. Looks cool man!
  20. Von Rigg Fink
    Von Rigg Fink
    from Garage
    those look like they might work.
    I have a set of the HF steel ones..total P.O.S. in my opinion.
    they might work on light cars but not a 3400 pound chevy.
    those wood ones look ok, how good are the casters?
    maybe I will get a set of those for the chevy and use the steel ones for the A
  21. montclaire
    montclaire
    I just picked four up - they were still on sale for $10 each. They're just to keep the thing mobile in the garage until I can strip it down and get to work. I'm certainly not going to be under it. One point, I did notice that some are made of thicker wood than others, so look them over and get the thicker ones.
  22. 4tl8ford
    4tl8ford
    from Erie, Pa
    I just bought two, I think that makes 7 sets of two and I still don't have any under my Panel Truck.
    I haven't been able to kill any yet.
    As with anything be careful with the balence.
  23. INXS
    INXS
    Bought two of those at Tractor Supply this past Sunday. Broke the casters off the first dolly almost as soon as we started to roll them. Actaually the whole caster assembly tipped over so the wheel was flatways to the cement. Took the second unused dolly back.
    Course we were moving a 413 Mopar...
  24. 35Chevy.com
    35Chevy.com
    from New Jersey
    Yes it started out with solid legs, later I added 4 boat trailer jacks and cut off the solid legs. The frame is made from 2 inch deck railing from Home Depot
    Gary
  25. Brad B
    Brad B
    from Nor Cal
  26. KING CHASSIS
    KING CHASSIS
    I work at a sign company and we probably have 75 of those HF dollies. When used like that( with the weight on the spreader boards) they break in half. Be careful.
  27. Big Tony
    Big Tony
    Big Ken used them on his 33 pu frame while mocking up with no problems. I have used them with motors, tranny's and rear ends. If needed beef them up with more boards.
  28. if your set on these add more wheels hf sells them too
  29. d2_willys
    d2_willys
    from Kansas
    Wouldn't put more than 500lbs on each of them.
  30. Funny thing about HF stuff, some of it works fine, some breaks with one use. Now that I think about it, I don't remember where I got my jackstands, but they have that orange paint on them, maybe I shouldn't trust 'em...
