Anyone On Here Able to Make Custom Water Transfer Decals?
Discussion in 'The Hokey Ass Message Board' started by Tony Bones, Apr 16, 2008.
  1. I have a custom decal I'd like to have a sheet of made, but I'd prefer if the end product is a water transfer, ala' old Ed Roth decals. Anyone able to help me out?
    Thanks.
  2. stude_trucks
    stude_trucks
    check tech section. I think there is a tech thread in there on that if I recall.
  3. Thirtycoup
    Thirtycoup
  4. Muttley
    Muttley
    I dont know anything about making them, all the decals I have are NOS.
  5. Thirtycoup
    Thirtycoup
    my bad - sorry about that, mike
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Whizzerick did a tech on it
    check out the tech archives
  7. NoSurf
    NoSurf
  8. Not to steal the thread, but how about to make gauge faces?
  9. 31hotrodsedan man
    31hotrodsedan man
    how big are you looking to go? cause if its model size they make sheets that you can run through your printer. spray a little fixative on and go for it. i know they have white, clear, and i have seen some metallic pages. ive had the best luck finding them in model train shops, but i would think many hobby shops would have them
  10. 55 dude
    55 dude
    the ones i had made for my 36' plymouth were done in the early 90's using a process called "offset reprographics". if the guy you are dealing with is honest when you ask him "how much for one?" he will reply "same as 12!":D:D sell the extras to pay for yours. these days they probably use scanners so shop around. post your results.
  11. timmy t
    timmy t
    like 31hotrodsedanman said hit your local hobby shop they should have decal sheets.all you do is scan your image and print. if you know anybody with an alps printer they work the best. The only problem is that alps printer arent produced anymore.
  12. Thanks guys, I'll look around and see if Reprographics is still going. It'd be a fun project to take on myself, but time is something I have less and less of these days and I'd rather spend it on working on something I'm really interested in.
    The responsibilities of being a grown-up seem to directly relate to having little hobby time.
    ****ed
  13. raceratrod
    raceratrod
    Spray clear over a printed page of what you want to transfer , soak it in warm water untill the paper disolves use a little elmers glue in water to make the transfer stick .You can respray with clear if its on a metal panel to protect it.
    p.s. the ink will transfer to the clear paint film which will be like a decal
  14. Pete1
    Pete1
    from Wa.
    If you are going to use the decals outdoors or where they will be exposed to sunight, you should use ink intended for outdoor use or they won't last long.
