MUSTANG T-5 Behind a 283?
Discussion in 'The Hokey Ass Message Board' started by Harrison, Apr 25, 2008.
  1. Harrison
    Harrison
    I may have found a 1994 Mustang T-5. I've rear & read in the tech archives & a lot of Flat Ernie's posts looking for the answer to my question but can't seem to find it.
    Is a '94 Mustang T-5 a good candidate to back a 283 with hydraulic clutch?
    TIA, JH
  2. el Scotto
    el Scotto
    from Tracy, CA
    The GM T-5 uses the popular GM ****** bolt pattern, and the Ford units use a Ford ****** bolt pattern. Unless you have a hybrid bellhousing or an adaptor plate, it won't work.
  3. SlowandLow63
    SlowandLow63
    from Central NJ
    Or you can use a Chevy main case (S10, Camaro, etc.) with the rest being Ford. From what I know the guts are interchangable as well as the main components.
  4. 73RR
    73RR
    Input shaft length is the same and you need a disc to match the splines. The bolt pattern at the bell is different but that is what welding/drilling/tapping is used for...but you'll also need to check the front bearing retainer OD and compare to the bell ID. These must be mated to maintain registration.
  5. fast Ed
    fast Ed
    94-95 Mustang 5.0L T-5 had a longer input shaft than the earlier 5.0L units, in case that's an issue. Not sure how that compares with the length needed on a Chev application, sorry.
    cheers
    Ed N.
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Ford input shaft lengths:
    4-cyl = 7.41"
    83-93 = 7.18"
    94-95 = 7.85"
    As mentioned, you'd either need a custom bellhousing or swap guts to GM pattern case (WC)
  7. bluestang67
    bluestang67
    Been about a year since i swapped the tail shafts to move shifter forward for the A . I think you could swap the bell housings and just make a spacer to make up difference of input shaft length . This is done on vintage stangs to adapt the T-5 . One other thing i think most the gears are the same but 5th ratio . Couple pics of inside chevy first then ford . I am no ****** expert though .
  8. willyswan
    willyswan
    from Austin, TX
