Way to check bad gas?
Discussion in 'The Hokey Ass Message Board' started by BeatUpFleetline, Apr 25, 2008.
  1. BeatUpFleetline
    BeatUpFleetline
    Is there a way to know if a few gallons of gas has gone bad or not? other than the time it has spent sitting someplace.:confused:
  2. SaltCityCustoms
    SaltCityCustoms
    You can usually tell by the smell, other than that I don't know....maybe a taste test.
  3. MIGHTY
    MIGHTY
    Throw a match on it!
  4. Adam D.
    Adam D.
    the correct way is to take a sip, and swish in around ur mouth, letting hit on all four taste centers.... let it dance on ur pallet, then spit it back into the tank.... use ur own discretion as to the freshness...
  5. 53chieftian
    53chieftian
    with todays gas, if its been in a can for a couple months its gonna stink weird! Wether that means its bad or not i dont know. Im sure its not the best but low performance engines will still run fine on it tho!
  6. 53sled
    53sled
    from KCMO
    Its bad. take it out any way you can and use it in the lawn mower, cut with a little fresh gas.
  7. R Pope
    R Pope
    Bad gas loses its clear colour, looks a bit dark. Stinks, too!
  8. K204DR
    K204DR
    from Chatt TN
    If it smells like ***, its probably bad gas!
  9. If in doubt throw it out......If you have at least half a tank in your driver mix it in.I have seen too many cars that ran rough because they used up their old boat gas etc in their cars.I wouldn,t even consider using it if I had my doubts about its quality.
  10. llonning
    llonning
    I deal with this on a daily basis. It's lawn mower season!!!! About 90% of what I do relates to old gas. 2 ways to check, smell, and stick your finger in it, it should tingle and start to evaporate immediately. If it smells bad or doesn't evaporate it is bad. NEVER, NEVER used old gas in a small engine!!!! You wouldn't believe the problems it causes a small engine! Labor rates right know on a fuel problem are 65.00 plus parts.
  11. BeatUpFleetline
    BeatUpFleetline
    I know how you feel, I work for the parks department, and on our larger mowers some are gas and some are diesel. The ones that run on gas don't get used all that often and sit for months at a time sometimes with a full or half tank and then it's my job to drain them and refill them. It ****ing ****s but that goes without saying.:mad:
  12. stretch 1320
    stretch 1320
    Pour it on a stump and burn it!
  13. lostn51
    lostn51
    from Tennessee
    when you smell the bad gas there will no doubt in your mind its bad. its one of those smells that you can not ever forget or get rid of kinda like gear oil........eeeewww.
