Anybody ever do an Extended cab El Camino?
Discussion in 'The Hokey Ass Message Board' started by boldventure, Apr 26, 2008.
  1. boldventure
    boldventure
    How 'bout some of the model builders who don't hate the very thought of ruining the cl***ic, timeless lines of the stock El Camino hack one of their old kits up and protoype this abomination? Or send me the "where to get" and I'll do a curbside just for the styling exercise!
  2. sdrodder
    sdrodder
    from Houston TX
    DO NOT DO IT. You would ruin 2 caminos I saw it done on a model car befor and it didnt look good. SO dont do it
  3. Swifster
    Swifster
    Again, if someone could do that drawing with the same length added to the front of the bed, extending the wheelbase, I'd bet it would be the cat's ***. The problem doing this conversion? The frame. That big 'X' frame would be hard to extend. The body wouldn't be any harder than many things cut up here.
    It kills me that most here would have no problem cutting and channelling a '32 Ford B-400 but whine and moan over a '59 or '60 El Camino :eek:.
  4. Dice
    Dice
    from Marion, TX
    We have a '60 El Camino in the shop for an extended conversion right now. The owner came up with the idea and had some conceptual drawings done before we started. It looks a lot better than you'd expect. We already have the metal work completed and are in the prime/block stage right now. I'll try to get some pics posted when I get back to work next week.
  5. VNTGE41
    VNTGE41
    from l.a.
    no dont do it!
  6. chaddilac
    chaddilac
    can I get some popcorn, i'm a little late...
  7. boldventure
    boldventure
    I would really like to see those pics. A look at at the drawing would be interesting as well!;)
  8. c57heaven
    c57heaven
    not my cup of beer ( I mean tea).
  9. boldventure
    boldventure
    Beer is usually served in a gl*** ain't it? :)
  10. jonzcustomshop
    jonzcustomshop
    I guess you could say my 60 has an extended cab , with the flattop rear window and roof, but that was not my intention in designing it that way, mine will have a good sized package tray(like the 4dr hdtp), but with the chop and section, there is no room for more than 2 people.
    the bubble top car has 4 seats, and alittle bit of an extended cab, but the design is completely different!
    A friend of mine has plans drawn up for a crew cab 59 elco, It dosen't look bad, but it will be really long!
  11. Judd
    Judd
    How about shortening the roof on a flat top 4dr and adding a bed area? I can't see any way you could modify a 59/60 elky with out frickin it up. A 59 is pretty close to perfect from the factory even in this Ford mans view.
  12. flynstone
    flynstone
    thats the ticket chop up a 4 door make a el camino...no harm no foul
  13. Rot 'n Kustom
    Rot 'n Kustom
    **** Dean built a stretched El Camino about 8-10 (?) years ago. There was pic in Rod & Custom magazine, in the "Roddin Around" section, if I recall. It may have been a quad cab. I'll see if I can locate a photo.
  14. James D
    James D
    Steve Stanford - hot rod artist/God. Did a lot of the sketchpad drawings in R and C in the `90s. I remember the drawing of the "crewcab Elky" and it was really a four door wagon with a bed on the back.
    More here...
    http://www.jalopyjournal.com/forum/showthread.php?t=105745&showall=1
    Jonzcustomshops Elky with the four door rear screen looks just great to me. Could be factory built.
  15. flyingpolock
    flyingpolock
    from PHX
    Cool... that's my sketch! (glad you liked the rough comp...)
    I had sketched that for a client (who is still going forward, albeit in a slightly new direction) back in January of '07.... the project fizzled, and next I knew, it was re-drawn (with some design changes) by another artist, and I guess it's back on for him.
    A lot of work to make an extended-cab El Camino.... I stretched it (in the drawing) about 8 inches, and was thinking of using a four-door donor car... the trickiest areas are in the bed, and creating the rear cab area. I was hesitant to change up the wheelbase, etc... IMO, El Camino's need just a drop, a mild shave and some cool paint... but, to each his own.
    Anyway, here's my initial loose sketch:
    ...and here's E.B.'s finished rendering:
  16. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Geez....there isnt enough room in the cab of a first gen El Cam already?? Please dont take the chance!
  17. Dice
    Dice
    from Marion, TX
    Yep, that's the car in my shop. I didn't realize any HAMBers were involved in the sketches---small world! Like he said, the direction has changed slightly during the build, but it's still basically the same with some minor changes in the details (trim, grill, etc). I'll keep you guys posted on the progress.
  18. 37FABRICATION
    37FABRICATION
    Could be a plastic 'cup' of beer...;) The ones that usually cost about $8.
  19. Squablow
    Squablow
    I'm pretty sure that was a '57 Ranchero. It did look pretty neat though, **** Dean is talented with **** like that. He really knows how to cut 'em. I'd like to meet him.
  20. Clark Kustoms
    Clark Kustoms
    from las vegas
    How about a wagon with 2 door doors ,then use the rest of the rear door area for thin third door. Open the rear doors suicide, and slide the roof farward to meet the door. Tell every one its a saturn.
    How about a crew cab made from a 4 door. heres i did for a guy from a 69 malibu.
  21. 2tall
    2tall
    I thinbk it might work but the body would need stretching too otherwise the proportions are out.
  22. How 'bout these...
  23. James66g
    James66g
    I have to cast my vote in the pickled *** side the 59 elko is a cl***ic factory kustom no need to **** it all up if you just gotta man do a 4 door instead at leat then you will be screwin up somthin no one else wanted any way
  24. metalshapes
    metalshapes
    To me, the '59 is very close to perfection.
    I even think Chevrolet messed it up by Facelifting it into the '60.
    And this Stretched Cab idea is much worse....
    It would be like drawing a Moustache on the Mona Lisa.
  25. A "Dirty Sanchez"? The extend one above, even though nicely finished, makes the door window look small. A lot of work, for what?
  26. Shaggy
    Shaggy
    from Sultan, WA
    There was one at the monroe Swapmeet 5 or 10 years ago it was a 64-67 dont really remember,
    My dad made a sedan delivery out of a 67 with a Olds Vista Crusier roof in the 80's and never finised it
  27. Swifster
    Swifster
    This was my thought exactly. I don't like the drop, but the rest isn't bad. With the extended wheelbase, the proportions look good. I like the Caddy conversion too.
  28. flyingpolock
    flyingpolock
    from PHX
    ...and this was my argument at the outset... By keeping the stock wheelbase and stretching the cab (thus shortening the bed area), it gets cartoon-y, and starts to look like an altered-wheelbase car (like in my sketch).
    IMO, starting with a roached 4-door, and using parts from some later-model, perhaps unsalvageable mess would be the way to go... you'd still have your unique El Camino, and could tailor the dimensions to look "right"...
    Best wishes no matter what direction you take!
  29. The Hank
    The Hank
    from CO
    I kinda disagree , In the drawings the car looks right with out extending the wheelbace. I don't see where you would need a doner car and if you did you could use a wagon for the roof. The gl*** in the extended part looks good in the drawings to to save on the labor factor that could be filled in with sheet metal. Maybe a port window like the Tbirds of 57. The Pic of the red one with the whole car extended while not looking wrong sure is long.
  30. Dice
    Dice
    from Marion, TX
    Here's a pic of the car during the build. The wheelbase worked out just fine with such a small addition to the cab area. It only required a little stretching of the roof to get it to this stage.
