Photoshop a 52 Desoto???
Discussion in 'The Hokey Ass Message Board' started by time_xx, Apr 16, 2008.
  1. naki kid
    naki kid
    If you look under the hotrod blowout nz post you will see a photo of my 52 dodge coronet Kustom with a homemade carson top,this car was a 4door sedan.
  2. PoopStain06
    PoopStain06
    from SoCal
    sectioning your car is the grand daddy of all custom jobs...
    "Sectioning is the act of removing a horizontal section from the body of a car, lowering the top half onto the bottom half and welding the result back together. The purpose is to reduce the overall height of the bodywork of the car. Like a roof chop."
    thank Wikipedia
  3. glendale
    glendale
    how bout a plymouth hardtop that is actualy chopped.
  4. 73RR
    73RR
    Greetings glendale, what is the actual window opening height of the chopped coupe???
  5. glendale
    glendale
    i'm not sure that I quite get your quesstion. I measured from the center of the door to the top of the window opening and it is about 12 inches. hope this helps. also we 4 inches total out.
  6. nosyjoe
    nosyjoe
    from california
    This one started as a 1950 Chrysler 4 door. But as you probably know, 1949 -52 mopars are similar.
  7. nosyjoe
    nosyjoe
    from california
