I have mopar 360 1984 total rebuild. Lifter noise on number 1 cylinder have done 3 separate 15 min run ins to normal operating temp. Set throttle to 2000 rpm. using 5w 20 oil oil pressure 35 at set rpm. Any suggestions to get rid of lifter I have removed valve cover set idle then punch rocker at lifter end no change, Raised rear of car a little to ensure oil flow to front. I do not want to tear down to replace one lifter all parts are new. Engine sounds like it has tons of power just annoying noise!! Bore 10 over rv cam offy intake stainless valves 35 degrees advance at 2000 Holley 650 vaccuum secondaries any help would be appreciated. Am i not waiting long enough for run in?
you might do a search on oil and zinc and stuff ....at this point , i wouldn't break in a cam with out it... there are a couple post on this , on here.... don't want to scare ya, but....does the rocker move as much as the others...? brandon
I will check valve height closed and compare? When i removed rocker cover I was able to compress lifter a little pushing hard.
remove oil and check for material some silvering is ok thats berring shelf coating. if ok then start engine without cover and put a hammer tip wooden end on rocker and get a feel on how much slop is in it ,some times holding the rocker down will spin lifter and pump it up .also the rocker could be bad i asume it has stock rockers look at the tip and cup for wear , the oil is way to thin .mopar restoration
So in a nutshell chane oil check for silvering in it put in 20/50 then start engine remove cover put pressure on lifter with wooden end of hammer and hope it pumps up. How long should it take to pump up and should I put any additives in to help if so what? Thanks to everyone
I worked at a dodge dealership in the 70's and some of the guys used to fish the lifters out of the pushrod cutouts in the heads.Not sure what engine
Take all the rocker arms off and lay a straight edge along the valve tips to run a quick check for the ***embled heighth. This will eliminate the guess work. If the valve that's ticking is lower you have found the problem. If all valves are the same you need to dig deeper to the lifters. I have seen people use too much SILICONE in ***embly that the **** gets in the lifters. Try the straight edge thing first>>>>.
