stock chevy rear end
Discussion in 'The Hokey Ass Message Board' started by bodydropped72, Apr 28, 2008.
  1. bodydropped72
    bodydropped72
    from bako,ca
    does anyone know the measurements of a stock 53 chevy car rear end looking for mounting flange to mounting flange for wheels found an 80s camaro rear end and wanna see if it will work
  2. 53sled
    53sled
    from KCMO
    http://www.carnut.com/specs/frear.html
    You will have to weld your own perches on and use positive offset (like 80s camaro, 4x4 s10) wheels as the later camaros are a bit wider than the early ones. 60" is what you need.
  3. 55 dude
    55 dude
    www.chevytalk.com will have any info on the swap you need,in fact almost any info on your car.
  4. bodydropped72
    bodydropped72
    from bako,ca
    ya i know all the basics already got the bellhousing thanks to another hamber, found this rear end has posi on craigslist for 80 bucks
  5. Wrench Wench
    Wrench Wench
    from Ohio
    We're doin' the same project...dropping a rear end from a 67 Camaro in our 53 Chevy 210. The Camaro rear end is set up for mono leaf so we'll have to do some modifications on the perches, but here is a great website on 49-54 Chevys (and from what I understand most of the info on this website came right here from the HAMB): http://50chevy.com/driveline.html Good luck with your project!
  6. old dirt tracker
    old dirt tracker
    from phoenix
    when you say 80,s do you mean the 70-81 rear or the 82 up. the 70-81 will work. the 82 up is to wide and very light duty.
  7. bodydropped72
    bodydropped72
    from bako,ca
    not sure im thinkin 82 and up im not lookin to put a small block or anything like that so...
  8. bodydropped72
    bodydropped72
    from bako,ca
    so the rear end this guy has, he says is roughly 61 1/2 inches wide im not plannin on puttin wide wheels on it so i believe this will work what do you guys think
  9. 53sled
    53sled
    from KCMO
    Keep looking. The wheel well is not very big in these cars, little room for error. 55-57 chevy, early nova, 70-81 camaro, s10 4x4 is a much better choice, and there are plenty out there. You'll regret it later, when you have to run funny wheels to make it fit.
  10. Snarl
    Snarl
    55-64 car rearends are useable, its just that on 58-64 versions you need to torch off a couple brackets and weld on some $15 spring perches. If you get one from a salvage yard, you can have them cut them off for you. Not a big deal. I would stay away from the 55-56 versions due to the axle bearing size.
