Ford 3 speed Transmission help needed in Milwaukee
Discussion in 'The Hokey Ass Message Board' started by bugbaron, May 4, 2008.
  1. bugbaron
    bugbaron
    from Milwaukee
    Is there anyone out there that might want to help out a new ford guy with a funny sound coming out of the trans. It only makes noise when shifting from 1st to 2nd all gears pull fine no other problems. Please PM me or give me a call 414-349-5431 thanks Tony
  2. bugbaron
    bugbaron
    from Milwaukee
    Maybe a good place to take in for repair???
  3. 59 brook
    59 brook
    hello tony? is that you this is jeff from south florida with the ford parts . it's a small world
  4. bugbaron
    bugbaron
    from Milwaukee
    Yep its me, Just looking for some local help first.
  5. CheaterRome
    CheaterRome
    from URANUS
    Contact CheaterCarl here on the message board, he can hook you up with any and all parts and or questions related to the grand old ford three speed toploader... he builds them in his spare time.
    He is located in Bay View as well.
    Cheaterome
  6. jonnycola
    jonnycola
    Yeah, carl is a ruler with those old three speeds.
  7. bugbaron
    bugbaron
    from Milwaukee
    Thanks, I'll give him a call.
  8. dirty old man
    dirty old man
    Last time I was inside one of those old 3 speed top loaders gotta be about 45 years ago, but Lord knows I spent enough time in them in the preceding 10 to still remember a bit about them.
    If the noise you hear while upshifting from 1st to 2nd is a bit of a gear clashing/grinding noise, then most likely the br*** ring on the 2nd gear (rear) side of the synchronizer outer hub is worn out and not matching the two dog clutches rpm with each other.
    If this has been going on for extended time you may find you have worn out teeth on the matching dog clutch teeth.YMMV
    To clarify, when I say dog clutches I'm referring to the meshing of an internally toothed, or splined, collar to an externally toothed, or splined hub.
    Dave
  9. axeman39
    axeman39
    from Saco Maine
    I have 3 or 4 of those toploader 3 speeds if ya need one pm me.
