Can you tell me what this headlight is called?
Discussion in 'The Hokey Ass Message Board' started by 3Mike6, May 7, 2008.
  1. 3Mike6
    3Mike6
    They're on my '36 parts truck...I need to find the gl*** for the top indicator housing.
    Wired Customs LLC likes this.
  2. eddie_zapien
    eddie_zapien
  3. 3Mike6
    3Mike6
    Care to eloborate just a bit;)
  4. Harrison
    Harrison
  5. 3Mike6
    3Mike6
    Cool, I'll send them a pic and see if they can help. The indentations of the indicator housing has me confused for ID.
  6. Bruce Lancaster
    Bruce Lancaster
    Can you shoot it from front, showing lens and rim latch?? I'm thinking stock with an odd signal light bolted on.
  7. 3Mike6
    3Mike6
    Ask, and ye shall receive!
  8. Bruce Lancaster
    Bruce Lancaster
    OK...sealed beam converted...general bucket shape looks stock, but I need to go find pics. Does stainless rim have a spring loaded latch down at bottom in that shadow??
  9. 3Mike6
    3Mike6
    I'll run out and check again, but I don't think so...I recall running my hand around it to see if I could easily take the rings off...I'll be back in a few...thanks for your help!
  10. 3Mike6
    3Mike6
    Dang, lost my connection for a bit...but the trim ring is held on by a screw,,,be\\never noticed it before...actually put my gl***es on and was able to read some writing on top of the indciator housing ...Dietz 820 B...also looks like the top of the headlamp bucket is indented for the indicator housing...certainly not an add-on thing.
    Any ideas?
    Thanks.
  11. wbrw32
    wbrw32
    I believe that the little light was originally a parking light....
  12. Loe
    Loe
    from CDA, ID
    i have the same exact headlights. the gl*** piece is round like a gl*** cap. not semi circle but complete like a thimble. lights on top are parking lights and are original to the design. keep your eye on ebay. i also might be able to come up with some replacement lenses.
  13. 3Mike6
    3Mike6
    Awesome...PM if you can come up with some PL lenses, I'd really like to run these, that have a nice look to them.
    Thanks
    Oh...any idea what they came from?
  14. Loe
    Loe
    from CDA, ID
    im not sure. aftermarket? stock. seen them on fords though. im using my parking light for blinkers.
  15. gassersteve
    gassersteve
    i would call it a front headlight.
  16. Bruce Lancaster
    Bruce Lancaster
    OK...I have an old Dietz catalog...will look for it
