Chopping a 51 chevy!!! lots o pics
Discussion in 'The Hokey Ass Message Board' started by Low, May 10, 2008.
  1. Low
    Low
    Ok, here it is started choppin this 51 Chevy 2 dr sedan a few days ago. Nothing crazy, 4 inch chop, and canted b pillars.
    started out with this
    started marking out cut lines. We cut the package tray out for reasons to be revealed further down the page
    rear window and package tray gone
    Roof off
    set the roof back on to look at how the pillars needed to move
    cut A pillars top and bottm, and B pillars top and bottom to lean them in to line up
    saved the curve out of the quarter window to finish off the newly chopped quarter window with a nice curve
    slightly bent the curve then tacked into place
    ok, here is why we cut out the package tray. after a lot of thinking we decided to move the rear gl*** forward iinstead of making the roof longer we mad ethe catwalk longer
    all gas hammerwelded of course :D
    ok, roof Shortened, and rear window tacked into place
    thats it for tonight more pics and such manana.
    sam
  2. Interesting idea, extending the catwalk. I will be interested to see the finished product.
    Good luck.
  3. Low
    Low
    ok, I cant fall asleep so here is a little more.
    here is what a finished hammerweld looks like. not much to grind
    new, extended catwalk welded [​IMG]
    here is the unchopped door top showing how much it was chopped
    new profile
    welded B pillar
  4. Preacher
    Preacher
    That thing is looking awesome... I can't wait to see the side profile with that extended catwalk
  5. aceuh
    aceuh
    Lookin good bro!
  6. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
  7. Danimal
    Danimal
    Nice work. Can't wait to see it in the sun!
  8. Florian
    Florian
  9. eliguzman
    eliguzman
  10. Low
    Low
    up for you morning guys
  11. JEPPA
    JEPPA
    Interesting approach to the rear window. I'm takeing notes and waiting to see more.
  12. Low
    Low
    and a quick little video of some hammer welding I guess it takes a few minutes before the video will work <object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/WRqbdKZAzoU"> </param> <embed src="http://www.youtube.com/v/WRqbdKZAzoU" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
  13. strike a poser
    strike a poser
    from Salinas,CA
    Wow, and all this time I thought hammer welding was a one man operation. That sure beats putting down the torch and finding the hammer & dolly with welding goggles!
  14. Low
    Low
    it is definitely doable as a one man thing, torch stand, and tools nearby. however it goes much faster and smoother with two guys. plus if you **** it up you can always blame the other guy :D
  15. Low
    Low
    welded A pillar.
    then smoothed out the welds. Gas welds require very little grinding
    shot the sail panels in, and test fitting the reshaped beltline trim.
    the belt line trim need a little straightening so I made this little dolly to fit inside the trim
    more to come....
  16. Low
    Low
    the reason we decided to move the window forward is that when you just lay it down, the sail panel gets HUGE. We decided that moving it forward gives the roof a more proportional look, and keeps the sail panel around the stock size. it also gives the whole car a more aggressive coupe look without the little coupe 1/4 windows
  17. punkabilly1306
    punkabilly1306
    from ohio
    is that pennywise i heard in the background? its lookin' good
  18. OLLIN
    OLLIN
    All The most successful sedan chops I have seen do this. looks good man!
  19. captainjunk#2
    captainjunk#2
    looks cool please post more pics as you finish up the chop
  20. Low
    Low
  21. GREAT LOOKING CHOP!!! Kustombuilder and Sam F did basically the same treatment by moving the rear window forward and extenting the catwalk. It really cleans it up.Todd
  22. Low
    Low
    SamF's is one baaaad chevy. it is one of the ones I looked at a bunch before starting this chop.
  23. Low
    Low
    up for you night time guys
  24. Kustom7777
    Kustom7777
    from Austin, TX
    that looks great,,,i like it when the catwalk area is extended,,,makes the car look more like a coupe in my opinion,,,,,,i gotta learn gas welding,,looks like fun,,,,,,,,,,,
    keep the pictures coming!
  25. o2bdone
    o2bdone
    from ontario,ca
    looks good man wish i had the guts to do mine
  26. Low
    Low
    we should be wrapping this chop up in the next couple days, and I will get some pics of it all leaded and cleaned up. Gas welding is pretty straight forward, its just a matter of getting over the fear of the flame. It can be pretty intimidating at first. Also I like to use the RG45 filler rod, it is plenty strong but the welds stay really maleable and dont crack very easily.
    Your shoebox is gonna be one crazy custom. cant wait to see that one done.
  27. BadLuck
    BadLuck
    Damn...you make it look sooo easy! Keep the pics comin'....lookin' good..:)
  28. Low
    Low
    a lot of time has gone into learning how to make it look easy :D Even though it is still not easy, just a couple wrong choices can ruin your whole chop.
  29. houtex63
    houtex63
    from houston
    nice work, looks bad***
  30. Preacher
    Preacher
    Can't wait to see some pics of the side profile of that roof... you made extending that catwalk look simple... nice work. Please keep the pics coming
