P/S Fluid Leaked- Brakes Affected?
Discussion in 'The Hokey Ass Message Board' started by 4woody, May 12, 2008.
  1. 4woody
    4woody
    An O-ring failed at my P/S pump, and it spewed fluid everywhere, including some that got on my driver's side brake. It is affecting the brake a bit- it makes some noise and now doesn't grab as well so the car pulls a little to the right under braking.
    Can I just clean the pads (Mid-80's GM truck style discs- the middle grade ones from NAPA) and drive it till any residue is gone, or will the pads need to be replaced?
  2. Bort62
    Bort62
    Just drive it, it will burn off ;)
  3. 4woody
    4woody
    Really?
    That smiley makes me think you are just kidding...
  4. replace the pads.
  5. Section 8
    Section 8
    from AZ
    Have you used brake cleaner to clean the rotor?
    Try to spray some between the pads and rotor too.
  6. Kramer
    Kramer
    The pads will absorb the oil and you won't get it out by spraying brake cleaner on them. Replace em.
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    Cheap as they are . Replace ,and do both sides. Pulling brakes are a PITA !
  8. I do this a lot to Both brakes and Clutch disc with oil on them. In fact I rince off all new brake parts with this stuff when doing a brake job. Go to Wall Mart. They have a Carburetor Cleaner in a Blue can with Red badge Called Super Tech Carburetor cleaner. It will rince all the oil compleatly out of the Pads. It's only $1.25 a can, your gonna like it. I even use it to clean out my Paint guns. It totally evaperates and leaves behind ZERO residue. It will turn your skin white and do not get it in your eyes. This is a killer cleaner. I buy it by the Case. It's also the best gl*** cleaner you can get your hands on.
    The Wizzard
  9. Goztrider
    Goztrider
    from Tulsa, OK
    Hell, I've had problems with pads before, and I've used a hand held belt sander to resurface the pads. Just hold it on and run the sander until you've run the desired amount off the pad. Even if the fluid soaked in, it won't have gone far.
    Of course, I'm probably going to be flamed for this, so I'll add the standard safety stuff. Use gloves to protect your fingers, do it in a well ventilated area and wear a respirator as the dust is asbestos and other **** like that.
    Or don't. However, shaving the pad will save having to replace it.
