teflon tape vs. gasoline question...
Discussion in 'The Hokey Ass Message Board' started by tred, May 12, 2008.
  1. tred
    tred
    is teflon tape rated for contact with gasoline or will it fall apart over time?
    i want to make a sight gauge for an aluminum gas tank and don't know what to seal the threaded fittings with.
    is there some sort of brush-on sealant i should use instead of the tape?
    thank you.
    tred
  2. brewsir
    brewsir
    no...it deteriorates..just drop a piece in a little fuel and watch what happens to it..it turns to goo. They make a teflon tape for gas lines (natural gas in your home) that comes in a yellow roll instead of blue...I'm not sure how it holds up to gas but it's what I use.
  3. I use a teflon paste that comes in a tube from the hardware store plumbing dept, works on everything and is easy to clean off excess. I recently had a leak on an original model "A" flared fuel line that runs from the tank to the firewall and just a light smear of the stuff on the flare. stopped the leak.
    Teflon tape sometimes is cut by the tightening of the threads and can be p***ed into the system. especially if used at the carburetor fittings.
  4. V4
    V4
    Find some Teflon paste pipe dope at the hardware store. It usually has a little brush under the cap. Read the bottle, it should say its rated for gasoline as well as other stuff.
    Model T1 likes this.
  5. The small tubes are cheaper. Just make sure it says that it works with gas!
  6. SinisterCustom
    SinisterCustom
    There is teflon tape rated for gasoline....it'll say right on the roll. The roll may be yellow like these.
  7. Dan10
    Dan10
    from Joplin
    I like the paste in a wet application. It flows and seals better from my experience.
  8. ELpolacko
    ELpolacko
    I have used paste with moderate sucess on aluminum to aluminum NPT fittings. I tried as an experiment using Anerobic sealant, kick***. No seapage anywhere.
  9. toddc
    toddc
    Teflon tape is a bit of a misnomer. Most so called "teflon" tapes have little to no teflon content. Proper teflon is resistant to nearly any chemical that is in general circulation.
    The "teflon" tape that is supplied with Chinese air tools, however, appears to be made from polyethylene shopping bags:eek:
    tomkelly88, Andamo and pat59 like this.
  10. That stuff aint for gasoline!
    It is for natural gas piping connections....
    verde742 likes this.
  11. Loc***e has a teflon bearing paste called PSP that is great on all threaded connections...(permatex and others make similar stuff)
    permatex aviation gasket sealant will do the job well.
    so will loc***e medium threadlocker (blue)
    teflon tape ****s....and moves away from threads when tightening fittings...pretty near useless stuff....
    everyone is using teflon bearing paste nowadays...
    gas pumper likes this.
  12. BigChief
    BigChief
    55willys and racingonerobb like this.
  13. bryan6902
    bryan6902
    Plastic shopping bags will work in a pinch, if you don't have any other options.
  14. vettes2
    vettes2
    from OKC, OK
    Loc***e # 565 Thread Sealant is what you need. "Suitable for exhaust systems, air conditioning fittings, fuel lines, water coolant systems and brake
    systems" This is industrial grade Pipe Sealant with Teflon. Item number 56521 comes in a 1.69 fluid oz tube. I have used this on my Three 2 barrel carb setups for 2 different builds over 15 years and never a leak. This is a thick white semi paste like stuff.
  15. oldsman71
    oldsman71
    never herd that befor
  16. oldsman71
    oldsman71
  17. SinisterCustom
    SinisterCustom
    Ya wanna throw down a $20 bet on that holmes???
    I've got a roll of it in my toolbox.....and it says FOR GASOLINE right the **** on it.:D
    I used it for the 4 97's on my car.....
    56shoebox likes this.
  18. Shaggy
    Shaggy
    from Sultan, WA
    Hmmm i've never had a problem, mabey i'm just lucky
  19. Bort62
    Bort62
    JB weld works awesome.
    As long as you don't plan on taking it apart.
    belair likes this.
  20. Toqwik
    Toqwik
    I read on the spectre gl*** fuel filters and fuel pressure regulator packages it says to seal all threads with teflon tape.
  21. Del Swanson
    Del Swanson
    from Racine, WI
    Hey guys, I'm a journeyman steamfitter. I would never use "teflon" tape on any natural gas, or gasoline lines. Like it was said in another response, little bits of the tape can dislodge from the fitting and end up in the tiny orrifices in natural gas valves, or carbs. I know people have used it in the past without problems, but it's not a good practice. If for some reason you can't use a correct paste and have to use teflon tape, start the tape two or three threads up from the end of the fitting, leaving less of a chance of contamination. Plus it looks cleaner when you wipe off the excess paste.
  22. enjenjo
    enjenjo
    from swanton oh
    Rector Seal. Available at most hardware stores.
  23. beamishstout
    beamishstout
    from vail, az
    I've had luck with some stuff plumbers and hvac guys use. It's called rector seal. Easy to clean up and doesnt wrap around your fingers every time you try to wrap threads.
  24. flatheadfever
    flatheadfever
    for tough to seal fittings use a little of both
  25. Gas is a slang term for gasoline which is not a gas but a fluid.
    G***es are such things as propane, butane, methane, carbon dioxide, hydrogen, helium, nitrogen, nitrous oxide, argon and oxygen. Gasoline has a higher molecular weight making it a fluid instead of a gas.
    In the end, it all depends on what the manufacturer meant when they wrote gas.
  26. racerlall
    racerlall
    from WA
    permatex #2 thread sealant the non Harding its sorta green. I think permatex is pate of lock tight now ?
  27. seb fontana
    seb fontana
    from ct
    Seven year old thread...Permatex/locktight/Henkel.....I have never seen instructions that say to use a specific Teflon tape for sealing when gasoline is involved..I have just started seeing on TV [them guys know everything, right?] to use a paste sealant along with the teflon, wtf? Supposed to be needed to keep threads from galling?
  28. Blue One
    Blue One
    from Alberta
    Old thread to be sure, but it needs correct information. Proper thread sealant for gasoline is Gasoila thread sealant compound.
    http://www.gasoila.com/
  29. flatheadfever
    flatheadfever
    Funny
    I was getting ready to respond and I see I did .....7 years ago lol
  30. Well, someday when your vehicle stops running and you tear into it and find little pieces of Teflon tape plugging up a jet. The stuff can and will shear off if you are not real carful
