For those not offended by air ride....
Discussion in 'The Hokey Ass Message Board' started by shifty50, May 13, 2008.
  1. Just finished wiring up my valves and thought I'd share. I fabbed a valve support/ground strap and mounted it to the bottom of the tank legs and then just zip tied everything to it. The extra wire in the center is in case I choose to switch positions of my lines I can just swap the wiring.
  2. Fresh469
    Fresh469
    from Benton, KY
    that is one of the cleanest tank/valve setups i have ever seen
  3. str8Pipe65's
    str8Pipe65's
    Nice set up- i am a big fan of clean set ups- the ones that get thrown in are the ones that fail- cool shit!
  4. Grunion
    Grunion
    Looks great but loose the plastic fittings they will cause you grief.
  5. 63_nova_ss
    63_nova_ss
    and where will you be mounting this setup?
    i always preferred the the front valves under the front, and the back valves under the back, with your air supply in a totally separate location. i like my components to be stealth and hidden away next to or under an existing part.
    but thats just my opinion. does look clean.
  6. Tin Can
    Tin Can
    Looks like a nice and clean setup
  7. tfeverfred
    tfeverfred
    I know very little about air ride systems, but I do know attention to detail. You have great attention to detail and I'm sure whatever you're working on is going to kick ass. Nice work, man.
  8. Fitysix
    Fitysix
    from Md.
    Nice set-up Shifty50. The wire routing is great but, if it were me I would cover the wires with either convoluted lume or snakeskin and a little heat shrink on your terminal ends. Again nice job.
    Fitysix
  9. Thanks for all the nice comments guys!
    That's actually how I've run other setups. This time the tank/valves are mounted in the trunk with the valves facing forward, basically hidden. The front bags are hardlined through the mount cups and then 90 back along the frame, so when you open the hood you don't see anything air related.
  10. ...care to snap a picture of that setup?
    -marty
  11. greendream
    greendream
    Very very clean setup! Looks good.
  12. Yeah nice! I too would like a pic of the front setup. Thanks
  13. James66g
    James66g
    Looks god man are you sure thats enough air? I have 3 tanks and I use em up pretty fast I am thinking about adding helium or co2 as a back up. I goota figure outa way to post pics man I think you would dig my set up
    James
  14. I'll try and remember to snap a pic of the front setup this weekend when I'm back at the shop.
    -James66g, yeah it will be plenty, 12 gal. with two compressors. I'm not into bouncing it around a lot just up and down to drive/park.
  15. lostn51
    lostn51
    from Tennessee
    i might bag my 49 for the heck of it, i like the slammed look when its parked but how is the ride quality? with the suspension i have in the 51 all new springs and lowered the traditional way it rides better than the wifes BMW.
  16. ...any luck on getting those pictures for us;)
  17. Modem took a shit, sorry about the delay....Pics as requested. Hardline through upper cup and then installed, rear setup minus the front air lines and the guage panel under the stock speaker grill.
  18. It rides smooth, and I don't have front shocks or a rear sway bay hooked up yet and never drove it stock so nothing to compare it to but other vehicles I have/have owned. Installing air is a pretty big job though when done right, LOTS of wiring and plumbing air lines, I changed my system three times before I finalized on what I ended up with.
  19. Bazooka
    Bazooka
    Thank you *right click save* :cool: :D
  20. Looks really nice man, top notch work. My only question is don't you want the front valves close to the bag to avoid body roll?Not being a dick, just curious because i have to plumb mine fairly soon.
  21. Slag Kustom
    Slag Kustom
    volume of air in the lines is so small it will not make much of a difference, but quick deflating may be effected by the size of the line.
  22. Zephyr3789
    Zephyr3789
    Looks really clean! I'm fairly new to installing bags... Just out of curiosity, is the a reason your valves are run straight from the tank and not through a manifold?
  23. duwty
    duwty
    should work great
    doing things right the first time is the way to go
    its pretty bad to have to work on your ride on the side of the road with it dropped all the way down
    brass fittings are the way to go
    those plastic fittings can be really unreliable
  24. Just like the response quote from Slag Kustom body roll doesn't seem to be an issue.
    Dumping/deflating was actually was too quick, like the car dropped out from under me so I put caps on the dump valves with holes drilled in them til I got the dump speed I wanted
    Just what I'm used to and good manifolds are pretty spendy compared.
    You're the second one to make a point of this, I've only found brass fittings with no angle options like my set up needs. Is there a source for them? I just got the ones I have from the local long haul truck suppliers, and they also don't seem to come in 3/8" valve 1/2" line configuration.
  25. Bazooka
    Bazooka
    http://www.whynotfab.com/
    This place sells some nice all metal nickle plated fittings...
  26. Thanks for the link!
