1954 235 valve adjustment
Discussion in 'The Hokey Ass Message Board' started by bubba823, May 15, 2008.
  1. bubba823
    bubba823
    from oklahoma
    I,ve did a search but did not find what I need.What is the procedure for valve adjustment on this motor? what do you set them at? Anyhelp would be appreciated......
  2. xderelict
    xderelict
  3. Ole don
    Ole don
    Intake .006, exhuast .016. Hot and running. If the motor has a gazillion miles on it, the rockers should be removed and have the faces ground. They get little holes worn in them and ruin your feeler gauges.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Question is this engine from a Powerglide car??? If so they have hydralic lifters. OldDon is right about the feeler guages and with wear you don't get a true reading. What I use is a set of narrow blade gages made for points and such,fits in the wore area.
  5. bubba823
    bubba823
    from oklahoma
    believe this is orig motor for car,it has a 3 speed manual trans
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    Ok Soild lifters then. Std shift cars had solids till 57-8 as i remember.We allways adjusted them warm and idling. Otherwise warm and go thru the firing order ,pull dist cap and make some chalk marks where the wire would be. Put in high gear and move the car FORWARD only till the rotor point to the cylinder you want.You will wish you had 3 hands running !! LOL
    PS '54 210 2 door was my first car in'59.
  7. bubba823
    bubba823
    from oklahoma
    thanks 4 info,I looked through link above found good info. but none with procedure of adjustment..but I think I'll give it a try.
  8. Road Runner
    Road Runner
  9. bubba823
    bubba823
    from oklahoma
    thanks,that is what I was lookin 4...
