T5 Info
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Jun 20, 2004.
  1. 40chev
    40chev
    I am looking at an S-10 T5 this evening or tommarow for parts (4.3 bellhousing, top plate and tailhousing) and would like to know if there are any mods to be done to switch the S-10 tailhousing with the camaro housing?? is it a direct swap?....also my tailsection has the elect speedo, will the cable speedo on the
    S-10 work with the camaro output shaft??
    will the camaro shifter work on an S-10 tailhousing or are they different as far as mounting and the ball end??
  2. Snarl
    Snarl
    The difference is about 1/2". Depending on your combo of parts, you may not have an issue. I don't do flatheads, or Fords for that matter, so I can't really help you there.
  3. Snarl
    Snarl
    If you want to run a mech speedo, that S10 better be a '87 or older and be using a mech. speedo to begin with.
    I guess the short answer is no. Use the wrong combination of years and applications, and you're screwed.
    While the tailhousing swap is more or less "direct", there are issues. The biggest is that the speedo is in a different spot, so some monkey business is needed to put the gear on the Camaro tailshaft. There is an article on this over at inliners.org . Otherwise, swap out the tailshaft. Of course, both ******s would need to be NWC to do this because all mech speedo S10s are NWC. If there is any fatigue of the tailshaft snout or the inside of the back end of the input shaft, they will need to be replaced. I've had good luck with Zumbrota Bearing & Gear. Low prices and fast service.
    There are some special tools needed to rebuild a T5, but they aren't expensive.
    The shifters should interchange.
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    This still doesn't p*** the sniff test. All the adapters used for putting S10 T5 into flatheads were originally designed to put GM Muncie, Saginaw, & T10 behind flathead. Therefore, the adapter is based on the input shaft length of these older 4-speeds. The T5 bolts in, no issues.
    I've got both a Camaro & an S10 T5, but they're in storage - you've really got my curiosity piqued. :D
    Do you want to swap just the tailhousing? If so, it will bolt on - you need to use the cover as well, but that will be self-critiquing...:D If you want to swap out tailshafts, snarl has given you great advice. The T5 link in the tech article has links within it to a rebuild manual & an ***embly (with pics) article. You may find these helpful.
    It's been a couple years since I popped one together - think I did everything with tools in my toolbox...whatcha referring to here?
  5. Snarl
    Snarl
    You'd better go dig through your stuff then. I am absolutely sure about the S10's being longer. I have 3 of them sitting in the garage right now. Just because it is a little longer, doesn't necessarily mean it won't still fit. If the tip of the shaft doesn't bottom out, or if the shoulder of the splines doesn't bottom out, then you could install it as is and be none the wiser. I think you're ***uming that because those adapters are made to work with the 4spds you listed, that that means the distance from the pilot bushing to the ****** case is the same as chevy intended it to be, but that isn't necessarily so. You could pull those trannies out , say 1/4", and they would still work fine. That may also be enough to make the longer S10 T5 work without modification. I'm not saying thats whats going on, but it is very possible.
    The tools are a heavy duty snap ring pliers, the kind with wide non-removable tips. Also one of those 2 piece bearing removers is helpful. A regular snap ring pliers with the removable tips, and a press to remove the bearings from the case. You will need these to do a full rebuild on a T5.
    According to your main posting, it says that 93-95 S10's were WC. What I'm curious about right now is what does the tailhousing on the WC S10 T5's look like? If it's got a Ford bolt pattern up front, I'm wondering if the speedo hole was changed as well? perhaps these are capable of using either type of speedo, which I've been told the typical Ford T5 can do??? If thats the case, it opens up some more posibilities for interchange....
  6. Flat Ernie
    Flat Ernie
    Tech Editor
    Nope - not doubting you at all - I never bothered to measure 'em side by side...seems someone recently did have a problem with the clutch disk jamming on the splines, so maybe that's part of the problem - don't remember the particulars right now...
    You mean everyone doesn't have those in the box? :D
    I've now had three people tell me they have a '93 S10 T5 - WC, but GM pattern. Also had two of them tell me they have WC S10 T5 w/4.03 ge****t. Had two others tell me '93 S10 w/Ford bolt pattern. So it could be an engine or application dependent thing...
    It's nearly impossible to talk about T5 in absolutes - seems there's always exceptions to every "rule" about them...
    Here's one I recently stumbled upon - late model Mustang V6 still uses T5 to this day & some of them - at least '05-07 - have forward shifters and very short tailshafts. Don't have gear ratios for them & I believe their shifter box uses a remote-type shifter (kind of like Astrovan - but all late-model Mustangs now have remote shifters I think). Here's a pic or two.
    These might be useful for space-limited swaps...
  7. tjm73
    tjm73
    Yes, all manual transmission Mustangs since 2005 have remote shifters to isolate noise, vibration and harmonics. They are rod actuated at least.
    And the V6 T5 ratios are:
    1st - 3.75
    2nd - 2.19
    3rd - 1.41
    4th - 1.00
    5th - 0.72
    If it's late model Mustang I know it or can find it quickly.
  8. safari-wagon
    safari-wagon
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Pretty good list - looks similar to the one I use - mine's in Excel so I can sort it though. I don't care for the way they've annotated WC in the description - would've rather seen a separate column for that, but...still useful for the gear ratios
  10. Timido
    Timido
    from Cincinnati
    The 4cl ford t-5 trans have some really deep gear ratios and are not as strong as the V-8 ones. The V8 mustang guys have run them before with a early pilot bearing The Late model 94 and up v6 t5s are good ones with slightly different ratios. I ran a 94 V6 trans for many years with a early V-8 input shaft . I have a t-5 that I am going to go through and put in my Comet with a Hydraulic clutch set up.
  11. Timido
    Timido
    from Cincinnati
  12. RandyZ
    RandyZ
    from murillo,on
    I just so happen to have both a s-10 and a camaro T5 apart. The s-10 has splines 0.250" longer and the pilot is 0.550" longer.
  13. Snarl
    Snarl
    The splines on the S10 versions are really short, and the input collar is very long. Usually you end up shortening the collar as well as the tip of the shaft, at least in "typical" Chevy applications. The short spline problem is usually handled by either lengthening the grooves with a dremel, making about an 1/8" thick spacer to go between the ****** and bellhousing, or grinding some off of the clutch hub. There is also another way to do it over at the inliners website. Apparently you can get a disc made using a Vega center hub which could eliminate the problem as well.
    Interesting to see those pictures. Looks like that version can only use the electric sender due to it being on center with the tailshaft. Oh well. I'd still like to see some pictures of a Ford patterned S10 T5...
  14. olrodder
    olrodder
    Some where in all this it's stated that all 93 up Gm T-5's used the Ford bell housing bolt pattern. Does this mean that Ford T-5's bolt up to 93 up Gm bellhousings? If that is the case, what else has to be changed to do this...... clutch, pressure plate, TO bearing, etc....?
    Correct me if I have this wrong...... the info here has been extremely helpful.
    Thank you to all involved.
  15. Flat Ernie
    Flat Ernie
    Tech Editor
  16. olrodder
    olrodder
    Ernie.... Thanks for getting back to me. I'll be more specific. What does it take to put a Mustang 5 speed behind a Chevy small block ( or any othe GM?). The Ford units seem to be super plentiful and less expensive than the GM stuff..... Just wondering. Thanks again, great info, nice folks.
  17. Flat Ernie
    Flat Ernie
    Tech Editor
    Well, I know Lakewood used to make a ****tershield to put a Ford toploader behind a SBC, but the input shaft length & bolt pattern are different. The solution here is the adapter the early Mustang crowd uses to put a T5 behind their 4-speed bellhousings. They're are all over eBay (I'd link to one, but I'm in a hurry - can do it later if you can't find one).
    I'm sure there are other options, but that's what pops into my head right now...
  18. Such a good thread, thanks to all who have posted!
  19. motorhead1945
    motorhead1945
    in reading several different information sources somewhere i found that the astro van bellhousing used the chevy bell to engine bolt pattern with the ford t-5 pattern to the ******. maybe someone has more specific info to share,im just sayin.
  20. Working Class Zero
    Working Class Zero
    Good info. Thanks for the effort typin it out. Helpfull!!!!
  21. willowbilly3
    willowbilly3
    from Sturgis
    What are the deficiencys of the 4 cyl mustang ******?
  22. Rocky
    Rocky
    Classified Editor
    Yeah, Ernie,,,I'm another guy who had a WC 93 S-10 ****** with the early chevy bolt pattern. I ran it behind an Offy adapter bolted to my 59AB flatmotor in my 33 ford pickup. I had to get out my "zippy wheel" on my die grinder and remove 3/8th inch from the tip of the pilot shaft. I also "clearanced" the S-10 clutch disc [26 spline] by grinding about 1/4 inch of spline out of the ****** side of the disc's splines so the disc could come back far enough and not stick on the input shaft where it runs outta spline. Nothin to it.
    Now, I have one of those silly late WC T-5s from a 2.5 four banger with the stupid ford pattern... It fits my lakewood ****tershield behind a chevy/GM motor [after redrilling and welding nuts on the backside] but how the hell am I supposed to attach it to my 59AB motor?
  23. Flat Ernie
    Flat Ernie
    Tech Editor
    Rocky - I wouldn't even know where to begin due to input shaft length issues. I'm sure it can be done (anything can be done given enough time and money!), but I'd prefer to start with a different box...I think Mac's in NZ sell the adapter to put a Ford T5 behind a flatty. Supposedly, the 8BA stamped steel bellhousing can be readily adapted to a Ford T5, but that doesn't help your 59A any...
  24. moefuzz
    moefuzz
    Ernie and all who contributed, this is one of the best tech threads ever, I sure appreciate the info....
    It took me a long while to find this, I think the web page that it was originally
    posted on is long gone but I had saved this to the Hard drive about 3 computers ago.....
    3 Computers and 3 X 80 gig hard drives that is.
    One day I'm going try and get all my info onto one drive because it
    shouldn't take 9 months to find a simple chart but ....
    Hope this works, And I Hope this helps,
    It's a comprehensive list of All T5 Tag numbers from 1352-001 Up.
    <link id="Main-File" href="../BorgWarnerT5.htm" rel="Main-File"><link href="filelist.xml" rel="File-List"><link href="editdata.mso" rel="Edit-Time-Data"><link href="T5%20TAG%20NUMBERS_files/stylesheet.css" rel="Stylesheet"><style>@page {margin: 1.0in .7in 1.0in .7in; mso-header-margin: .5in; mso-footer-margin: .75in; } TABLE { mso-displayed-decimal-separator: "."; mso-displayed-thousand-separator: "," } </style><script language="JavaScript"> <!-- function fnUpdateTabs() { if (parent.window.g_iIEVer>=4) { if (parent.do***ent.readyState=="complete" && parent.frames['frTabs'].do***ent.readyState=="complete") parent.fnSetActiveSheet(0); else window.setTimeout("fnUpdateTabs();",150); } } if (window.name!="frSheet") window.location.replace("../BorgWarnerT5.htm"); else fnUpdateTabs(); //--> </script><table style="table-layout: fixed; width: 673pt; border-collapse: collapse;" x:str="" width="896" border="0" cellpadding="0" cellspacing="0"> <colgroup> <col cl***="xl28" style="width: 42pt;" width="56"> <col cl***="xl30" style="width: 58pt;" width="77"> <col cl***="xl30" style="width: 53pt;" width="70"> <col cl***="xl30" style="width: 84pt;" width="112"> <col cl***="xl26" style="width: 74pt;" width="98"> <col cl***="xl30" style="width: 42pt;" width="56"> <col cl***="xl27" style="width: 42pt;" span="6" width="56"> <col cl***="xl30" style="width: 42pt;" width="56"> <col cl***="xl30" style="width: 26pt;" width="35"> <col cl***="xl29" style="width: 53pt;" span="242" width="70"> </colgroup><tbody> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="width: 42pt; height: 12.75pt;" width="56" height="17">Tag No.</td> <td cl***="xl30" style="width: 58pt;" width="77">Make</td> <td cl***="xl30" style="width: 53pt;" width="70">Year</td> <td cl***="xl30" style="width: 84pt;" x:str="Model " width="112">Model </td> <td cl***="xl26" style="width: 74pt;" x:str="Engine " width="98">Engine </td> <td cl***="xl30" style="width: 42pt;" width="56">Torque</td> <td cl***="xl27" style="width: 42pt;" width="56">1st</td> <td cl***="xl27" style="width: 42pt;" width="56">2nd</td> <td cl***="xl27" style="width: 42pt;" width="56">3rd</td> <td cl***="xl27" style="width: 42pt;" width="56">4th</td> <td cl***="xl27" style="width: 42pt;" width="56">5th</td> <td cl***="xl27" style="width: 42pt;" width="56">R</td> <td cl***="xl30" style="width: 42pt;" width="56">Speedo</td> <td cl***="xl30" style="width: 26pt;" width="35">WC</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" height="17">1352-</td> <td cl***="xl30" style="" colspan="3"> </td> <td cl***="xl26"> </td> <td cl***="xl30">Rating</td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="1" align="right" height="17">001</td> <td cl***="xl30">AMC</td> <td cl***="xl30">82-83</td> <td cl***="xl30">P***</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="2" x:fmla="=A3+1" align="right" height="17">002</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="3" x:fmla="=A4+1" align="right" height="17">003</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="4" x:fmla="=A5+1" align="right" height="17">004</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">280Z</td> <td cl***="xl26">2.8 L6 Turbo</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="5" x:fmla="=A6+1" align="right" height="17">005</td> <td cl***="xl30">GM</td> <td cl***="xl30">84-86</td> <td cl***="xl30">Chevette</td> <td cl***="xl26">1.6 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="6" x:fmla="=A7+1" align="right" height="17">006</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">P***</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="7" x:fmla="=A8+1" align="right" height="17">007</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="8" x:fmla="=A9+1" align="right" height="17">008</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="9" x:fmla="=A10+1" align="right" height="17">009</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="10" x:fmla="=A11+1" align="right" height="17">010</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">S10</td> <td cl***="xl26">all</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="11" x:fmla="=A12+1" align="right" height="17">011</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="12" x:fmla="=A13+1" align="right" height="17">012</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="13" x:fmla="=A14+1" align="right" height="17">013</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">T" truck</td> <td cl***="xl26">4 & 6 cyl</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="14" x:fmla="=A15+1" align="right" height="17">014</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">T" truck</td> <td cl***="xl26">4 cyl all</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="15" x:fmla="=A16+1" align="right" height="17">015</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="16" x:fmla="=A17+1" align="right" height="17">016</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="17" x:fmla="=A18+1" align="right" height="17">017</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="18" x:fmla="=A19+1" align="right" height="17">018</td> <td cl***="xl30">Ford</td> <td cl***="xl30">83-84</td> <td cl***="xl30">T-Bird/Mustang</td> <td cl***="xl26">2.3 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="19" x:fmla="=A20+1" align="right" height="17">019</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">P***</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="20" x:fmla="=A21+1" align="right" height="17">020</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">Jeep</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="21" x:fmla="=A22+1" align="right" height="17">021</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">P***</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="22" x:fmla="=A23+1" align="right" height="17">022</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">82</td> <td cl***="xl30">Jeep</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="23" x:fmla="=A24+1" align="right" height="17">023</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">Jeep</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="24" x:fmla="=A25+1" align="right" height="17">024</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">Jeep</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="25" x:fmla="=A26+1" align="right" height="17">025</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">Jeep</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="26" x:fmla="=A27+1" align="right" height="17">026</td> <td cl***="xl30">AMC</td> <td cl***="xl30"> </td> <td cl***="xl30">Jeep</td> <td cl***="xl26">2.1L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="27" x:fmla="=A28+1" align="right" height="17">027</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="28" x:fmla="=A29+1" align="right" height="17">028</td> <td cl***="xl30">GM</td> <td cl***="xl30">83-87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl31">5.0 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="29" x:fmla="=A30+1" align="right" height="17">029</td> <td cl***="xl30">AMC</td> <td cl***="xl25" x:num="83">83 </td> <td cl***="xl30">1/12 Jeep XJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="30" x:fmla="=A31+1" align="right" height="17">030</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">1/12 Jeep XJ</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="31" x:fmla="=A32+1" align="right" height="17">031</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">T-Bird/Mustang</td> <td cl***="xl26">2.3 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="32" x:fmla="=A33+1" align="right" height="17">032</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">280ZX Europe</td> <td cl***="xl26">2.8 L6 Turbo</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="33" x:fmla="=A34+1" align="right" height="17">033</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.0L4, 2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="34" x:fmla="=A35+1" align="right" height="17">034</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">SVO</td> <td cl***="xl26">5.0 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="35" x:fmla="=A36+1" align="right" height="17">035</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.1L4D, 2.2L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="36" x:fmla="=A37+1" align="right" height="17">036</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="37" x:fmla="=A38+1" align="right" height="17">037</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="38" x:fmla="=A39+1" align="right" height="17">038</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="39" x:fmla="=A40+1" align="right" height="17">039</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="40" x:fmla="=A41+1" align="right" height="17">040</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Jeep XJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="41" x:fmla="=A42+1" align="right" height="17">041</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Jeep SJ</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="42" x:fmla="=A43+1" align="right" height="17">042</td> <td cl***="xl30">GM</td> <td cl***="xl30">84-85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="43" x:fmla="=A44+1" align="right" height="17">043</td> <td cl***="xl30">GM</td> <td cl***="xl30">84-85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="44" x:fmla="=A45+1" align="right" height="17">044</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">1/12 Jeep CJ RH</td> <td cl***="xl26">2.1L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="45" x:fmla="=A46+1" align="right" height="17">045</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="46" x:fmla="=A47+1" align="right" height="17">046</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">83</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="47" x:fmla="=A48+1" align="right" height="17">047</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">280ZX</td> <td cl***="xl26">2.8L6Turbo</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="48" x:fmla="=A49+1" align="right" height="17">048</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="49" x:fmla="=A50+1" align="right" height="17">049</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="50" x:fmla="=A51+1" align="right" height="17">050</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.5L4, 2586L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="51" x:fmla="=A52+1" align="right" height="17">051</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="52" x:fmla="=A53+1" align="right" height="17">052</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.1L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="53" x:fmla="=A54+1" align="right" height="17">053</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep CJ RHD</td> <td cl***="xl26">2.1L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="54" x:fmla="=A55+1" align="right" height="17">054</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.42</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="55" x:fmla="=A56+1" align="right" height="17">055</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">S10</td> <td cl***="xl26">1.9 L4 Isuzu</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="56" x:fmla="=A57+1" align="right" height="17">056</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.0 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="57" x:fmla="=A58+1" align="right" height="17">057</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">S10</td> <td cl***="xl26">1.9 L4 Isuzu</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="58" x:fmla="=A59+1" align="right" height="17">058</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.0L4 2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="59" x:fmla="=A60+1" align="right" height="17">059</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep XJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="60" x:fmla="=A61+1" align="right" height="17">060</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep XJ</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="61" x:fmla="=A62+1" align="right" height="17">061</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="62" x:fmla="=A63+1" align="right" height="17">062</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="63" x:fmla="=A64+1" align="right" height="17">063</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="64" x:fmla="=A65+1" align="right" height="17">064</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="65" x:fmla="=A66+1" align="right" height="17">065</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">5.0 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="66" x:fmla="=A67+1" align="right" height="17">066</td> <td cl***="xl30">AWSF</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="67" x:fmla="=A68+1" align="right" height="17">067</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">SVO w/Hurst</td> <td cl***="xl26">2.3 EFI T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="68" x:fmla="=A69+1" align="right" height="17">068</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">300ZX na/EUR</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="69" x:fmla="=A70+1" align="right" height="17">069</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">300ZX na/EUR</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="70" x:fmla="=A71+1" align="right" height="17">070</td> <td cl***="xl30">GM</td> <td cl***="xl25" x:num="84.5">84 1/2 </td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0V8LG4,LG9</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="71" x:fmla="=A72+1" align="right" height="17">071</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.76</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="72" x:fmla="=A73+1" align="right" height="17">072</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="73" x:fmla="=A74+1" align="right" height="17">073</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="74" x:fmla="=A75+1" align="right" height="17">074</td> <td cl***="xl30">AMC</td> <td cl***="xl30">85-86</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">258 L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="75" x:fmla="=A76+1" align="right" height="17">075</td> <td cl***="xl30">AMC</td> <td cl***="xl25" x:num="84.5">84 1/2 </td> <td cl***="xl30">Eagle</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="76" x:fmla="=A77+1" align="right" height="17">076</td> <td cl***="xl30">AMC</td> <td cl***="xl30">85-86</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.5L4, 258L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="77" x:fmla="=A78+1" align="right" height="17">077</td> <td cl***="xl30">AMC</td> <td cl***="xl30">85-86</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">258L6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="78" x:fmla="=A79+1" align="right" height="17">078</td> <td cl***="xl30">AMC</td> <td cl***="xl25" x:num="84.5">84 1/2 </td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="79" x:fmla="=A80+1" align="right" height="17">079</td> <td cl***="xl30">AMC</td> <td cl***="xl30">85-86</td> <td cl***="xl30">Jeep CJ</td> <td cl***="xl26">2.1 L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="80" x:fmla="=A81+1" align="right" height="17">080</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">300ZX</td> <td cl***="xl26">3.0 V6 T</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="81" x:fmla="=A82+1" align="right" height="17">081</td> <td cl***="xl30">Nissan</td> <td cl***="xl30">85-86</td> <td cl***="xl30">300ZX Euro</td> <td cl***="xl26">3.0 V6 T</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="82" x:fmla="=A83+1" align="right" height="17">082</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Eagle</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="83" x:fmla="=A84+1" align="right" height="17">083</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.42</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="84" x:fmla="=A85+1" align="right" height="17">084</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="85" x:fmla="=A86+1" align="right" height="17">085</td> <td cl***="xl30">AMC</td> <td cl***="xl30" x:num="">84</td> <td cl***="xl30">Jeep XJ</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="86" x:fmla="=A87+1" align="right" height="17">086</td> <td cl***="xl30">AMC</td> <td cl***="xl30">84,85,86</td> <td cl***="xl30">Eagle</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="87" x:fmla="=A88+1" align="right" height="17">087</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="88" x:fmla="=A89+1" align="right" height="17">088</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="89" x:fmla="=A90+1" align="right" height="17">089</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="90" x:fmla="=A91+1" align="right" height="17">090</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="91" x:fmla="=A92+1" align="right" height="17">091</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="92" x:fmla="=A93+1" align="right" height="17">092</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="93" x:fmla="=A94+1" align="right" height="17">093</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="94" x:fmla="=A95+1" align="right" height="17">094</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="95" x:fmla="=A96+1" align="right" height="17">095</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="96" x:fmla="=A97+1" align="right" height="17">096</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="97" x:fmla="=A98+1" align="right" height="17">097</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="98" x:fmla="=A99+1" align="right" height="17">098</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="99" x:fmla="=A100+1" align="right" height="17">099</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A101+1" align="right" height="17">100</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A102+1" align="right" height="17">101</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A103+1" align="right" height="17">102</td> <td cl***="xl30">GM</td> <td cl***="xl30">85-86</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">2.5L4,2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A104+1" align="right" height="17">103</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A105+1" align="right" height="17">104</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A106+1" align="right" height="17">105</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A107+1" align="right" height="17">106</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A108+1" align="right" height="17">107</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.2L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A109+1" align="right" height="17">108</td> <td cl***="xl30">GM</td> <td cl***="xl30">85-86</td> <td cl***="xl30">S10 (T?)</td> <td cl***="xl26">2.5L4,2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A110+1" align="right" height="17">109</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A111+1" align="right" height="17">110</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.5L4,2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A112+1" align="right" height="17">111</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A113+1" align="right" height="17">112</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A114+1" align="right" height="17">113</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A115+1" align="right" height="17">114</td> <td cl***="xl30">Ford</td> <td cl***="xl30">85-86</td> <td cl***="xl30">T-Bird/Mustang</td> <td cl***="xl26">2.3 T</td> <td cl***="xl30" x:num="">235</td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.81</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30">6T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A116+1" align="right" height="17">115</td> <td cl***="xl30">Motorsport</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">305</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">6T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A117+1" align="right" height="17">116</td> <td cl***="xl30">Ford</td> <td cl***="xl30">85-86</td> <td cl***="xl30">SVO</td> <td cl***="xl26">2.3 T</td> <td cl***="xl30" x:num="">250</td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30">6T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A118+1" align="right" height="17">117</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A119+1" align="right" height="17">118</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A120+1" align="right" height="17">119</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A121+1" align="right" height="17">120</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A122+1" align="right" height="17">121</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A123+1" align="right" height="17">122</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A124+1" align="right" height="17">123</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A125+1" align="right" height="17">124</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A126+1" align="right" height="17">125</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A127+1" align="right" height="17">126</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Mustang/Capri</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A128+1" align="right" height="17">127</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A129+1" align="right" height="17">128</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A130+1" align="right" height="17">129</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A131+1" align="right" height="17">130</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A132+1" align="right" height="17">131</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A133+1" align="right" height="17">132</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A134+1" align="right" height="17">133</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A135+1" align="right" height="17">134</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">UK-SVO Sierra</td> <td cl***="xl26">2.0 L4 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A136+1" align="right" height="17">135</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A137+1" align="right" height="17">136</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.2L4 Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A138+1" align="right" height="17">137</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A139+1" align="right" height="17">138</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A140+1" align="right" height="17">139</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A141+1" align="right" height="17">140</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A142+1" align="right" height="17">141</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Mustang/Capri</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A143+1" align="right" height="17">142</td> <td cl***="xl30">Ford</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A144+1" align="right" height="17">143</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A145+1" align="right" height="17">144</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A146+1" align="right" height="17">145</td> <td cl***="xl30">GM</td> <td cl***="xl30">85-86</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.5L4, 2.8V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A147+1" align="right" height="17">146</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">S10</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.49</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A148+1" align="right" height="17">147</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A149+1" align="right" height="17">148</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">85</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A150+1" align="right" height="17">149</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A151+1" align="right" height="17">150</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A152+1" align="right" height="17">151</td> <td cl***="xl30">Nissan</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">300ZX US</td> <td cl***="xl26">3.0 V6 T</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">2.06</td> <td cl***="xl27" x:num="">1.38</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.75</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A153+1" align="right" height="17">152</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A154+1" align="right" height="17">153</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A155+1" align="right" height="17">154</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Mustang/Capri</td> <td cl***="xl26" x:num="">2.3</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.85</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A156+1" align="right" height="17">155</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">T-Bird/Cougar</td> <td cl***="xl26">2.3T</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.79</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">6T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A157+1" align="right" height="17">156</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8 V6 LB8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A158+1" align="right" height="17">157</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0V8LG4-LG9</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl32" style="height: 12.75pt;" height="17">*</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 LG4/L69</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl32" style="height: 12.75pt;" height="17">*</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 LG4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl32" style="height: 12.75pt;" height="17">*</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 L69</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.61</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A159+1" align="right" height="17">158</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.5L4-LQ9</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.42</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.86</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A163+1" align="right" height="17">159</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0V8-LG4</td> <td cl***="xl30"> </td> <td cl***="xl27">see157</td> <td cl***="xl27" style="" colspan="5"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A164+1" align="right" height="17">160</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0V8-L69</td> <td cl***="xl30"> </td> <td cl***="xl27">see157</td> <td cl***="xl27" style="" colspan="5"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A165+1" align="right" height="17">161</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8V6-LB8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.78</td> <td cl***="xl27" x:num="">3.39</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A166+1" align="right" height="17">162</td> <td cl***="xl30">Ford</td> <td cl***="xl30">87-88</td> <td cl***="xl30">Mustang/Capri</td> <td cl***="xl26" x:num="">2.3</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.79</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A167+1" align="right" height="17">163</td> <td cl***="xl30">BTR</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A168+1" align="right" height="17">164</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A169+1" align="right" height="17">165</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">86</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A170+1" align="right" height="17">166</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0-LB9(3.08)</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A171+1" align="right" height="17">167</td> <td cl***="xl30">Ford</td> <td cl***="xl25" x:num="86.5">86 1/2 </td> <td cl***="xl30">T-Bird/Cougar</td> <td cl***="xl26">2.3 L4 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A172+1" align="right" height="17">168</td> <td cl***="xl30">Ford</td> <td cl***="xl25" x:num="86.5">86 1/2 </td> <td cl***="xl30">SVO Mustang</td> <td cl***="xl26">2.3 L4 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A173+1" align="right" height="17">169</td> <td cl***="xl30">Ford</td> <td cl***="xl30">86.5-89</td> <td cl***="xl30">Mustang/Capri</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A174+1" align="right" height="17">170</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">88</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A175+1" align="right" height="17">171</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A176+1" align="right" height="17">172</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A177+1" align="right" height="17">173</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A178+1" align="right" height="17">174</td> <td cl***="xl30">Cosworth</td> <td cl***="xl30"> </td> <td cl***="xl30">Sierra</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A179+1" align="right" height="17">175</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">88</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0RacingLB9</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A180+1" align="right" height="17">176</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">88</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 L03</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A181+1" align="right" height="17">177</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">88</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8V6 - LB8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.76</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A182+1" align="right" height="17">178</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 LB9</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A183+1" align="right" height="17">179</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A184+1" align="right" height="17">180</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A185+1" align="right" height="17">181</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">4.03</td> <td cl***="xl27" x:num="">2.37</td> <td cl***="xl27" x:num="">1.50</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.76</td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A186+1" align="right" height="17">182</td> <td cl***="xl30">GM</td> <td cl***="xl30">87-88</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 LB9 (3.08)</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A187+1" align="right" height="17">183</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 LB9</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A188+1" align="right" height="17">184</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">88</td> <td cl***="xl30">Sierra</td> <td cl***="xl26">2.0 L4 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A189+1" align="right" height="17">185</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">87</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">V8</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.36</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A190+1" align="right" height="17">186</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A191+1" align="right" height="17">187</td> <td cl***="xl30">BTR</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26">LB9</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A192+1" align="right" height="17">188</td> <td cl***="xl30">BTR</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A193+1" align="right" height="17">189</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">4.3L V6</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.50</td> <td cl***="xl27" x:num="">2.14</td> <td cl***="xl27" x:num="">1.39</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A194+1" align="right" height="17">190</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Minivan</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A195+1" align="right" height="17">191</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">T-Truck</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A196+1" align="right" height="17">192</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.8 V6 Only</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A197+1" align="right" height="17">193</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.5 L4 Only</td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A198+1" align="right" height="17">194</td> <td cl***="xl30">Ford</td> <td cl***="xl30">89-90</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">2.3</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.79</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A199+1" align="right" height="17">195</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 - L89</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A200+1" align="right" height="17">196</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">5.0 - L03</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A201+1" align="right" height="17">197</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">89</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8V6-LB8</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A202+1" align="right" height="17">198</td> <td cl***="xl30">Isuzu</td> <td cl***="xl30"> </td> <td cl***="xl30">Rodeo</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A203+1" align="right" height="17">199</td> <td cl***="xl30">Ford</td> <td cl***="xl30">90-91</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">300</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr cl***="xl24" style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A204+1" align="right" height="17">200</td> <td cl***="xl30">Motorsport</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">305</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A205+1" align="right" height="17">201</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">90</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" x:num="">3.76</td> <td cl***="xl27" x:num="">2.18</td> <td cl***="xl27" x:num="">1.41</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.72</td> <td cl***="xl27"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A206+1" align="right" height="17">202</td> <td cl***="xl30">Aftermarket</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">305</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.80</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A207+1" align="right" height="17">203</td> <td cl***="xl30">Panther</td> <td cl***="xl30"> </td> <td cl***="xl30">Solo</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A208+1" align="right" height="17">204</td> <td cl***="xl30">Service</td> <td cl***="xl30">85-89</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">300</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A209+1" align="right" height="17">205</td> <td cl***="xl30">Melroe</td> <td cl***="xl30"> </td> <td cl***="xl30">Spray Coupe</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A210+1" align="right" height="17">206</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">92</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A211+1" align="right" height="17">207</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">91</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">2.3</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.79</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A212+1" align="right" height="17">208</td> <td cl***="xl30">Ford</td> <td cl***="xl30">92-93</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">300</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A213+1" align="right" height="17">209</td> <td cl***="xl30">Ford</td> <td cl***="xl30">92-93</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">2.3</td> <td cl***="xl30" x:num="">240</td> <td cl***="xl27" x:num="">3.97</td> <td cl***="xl27" x:num="">2.34</td> <td cl***="xl27" x:num="">1.46</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.79</td> <td cl***="xl27" x:num="">3.70</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A214+1" align="right" height="17">210</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">3.4L V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A215+1" align="right" height="17">211</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">92</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30" style="" colspan="2"> </td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A216+1" align="right" height="17">212</td> <td cl***="xl30">GM</td> <td cl***="xl25" x:num="92.5">92 1/2 </td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A217+1" align="right" height="17">213</td> <td cl***="xl30">GM</td> <td cl***="xl25" x:num="92.5">92 1/2 </td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A218+1" align="right" height="17">214</td> <td cl***="xl30">GM</td> <td cl***="xl25" x:num="92.5">92 1/2 </td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A219+1" align="right" height="17">215</td> <td cl***="xl30">Isuzu</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">Rodeo</td> <td cl***="xl26">2.0 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A220+1" align="right" height="17">216</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.2L</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A221+1" align="right" height="17">217</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A222+1" align="right" height="17">218</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">Cobra</td> <td cl***="xl30" x:num="">310</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A223+1" align="right" height="17">219</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">94</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">300</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A224+1" align="right" height="17">220</td> <td cl***="xl30">Ford</td> <td cl***="xl30" x:num="">94</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">3.8</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A225+1" align="right" height="17">221</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A226+1" align="right" height="17">222</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">S-Truck</td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A227+1" align="right" height="17">223</td> <td cl***="xl30">BW</td> <td cl***="xl30"> </td> <td cl***="xl30">4 X 4</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A228+1" align="right" height="17">224</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A229+1" align="right" height="17">225</td> <td cl***="xl30">Aftermarket</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">325</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.80</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A230+1" align="right" height="17">226</td> <td cl***="xl30">Ssang</td> <td cl***="xl30"> </td> <td cl***="xl30">FJ 4 X 4</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A231+1" align="right" height="17">227</td> <td cl***="xl30">Motorsport</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">325</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A232+1" align="right" height="17">228</td> <td cl***="xl30">GM</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A233+1" align="right" height="17">229</td> <td cl***="xl30">Melroe</td> <td cl***="xl30"> </td> <td cl***="xl30">Sprayer</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A234+1" align="right" height="17">230</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A235+1" align="right" height="17">231</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A236+1" align="right" height="17">232</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30"> </td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A237+1" align="right" height="17">233</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30"> </td> <td cl***="xl26">2.5 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A238+1" align="right" height="17">234</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30"> </td> <td cl***="xl26">2.8 V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A239+1" align="right" height="17">235</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A240+1" align="right" height="17">236</td> <td cl***="xl30">Ford</td> <td cl***="xl25" x:num="94.5">94 1/2 </td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">3.8</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A241+1" align="right" height="17">237</td> <td cl***="xl30">Ssang</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A242+1" align="right" height="17">238</td> <td cl***="xl30">Ford</td> <td cl***="xl30">94-97</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">3.8</td> <td cl***="xl30" x:num="">265</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.93</td> <td cl***="xl27" x:num="">1.29</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A243+1" align="right" height="17">239</td> <td cl***="xl30">Aftermarket</td> <td cl***="xl30" x:num="">93</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">Cobra</td> <td cl***="xl30" x:num="">310</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A244+1" align="right" height="17">240</td> <td cl***="xl30">TVR</td> <td cl***="xl30"> </td> <td cl***="xl30">Griffith</td> <td cl***="xl26">4.3 V8</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A245+1" align="right" height="17">241</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A246+1" align="right" height="17">242</td> <td cl***="xl30">Ford</td> <td cl***="xl30">94-95</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">Cobra</td> <td cl***="xl30" x:num="">310</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A247+1" align="right" height="17">243</td> <td cl***="xl30">Ssang</td> <td cl***="xl30"> </td> <td cl***="xl30">4 X 4</td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A248+1" align="right" height="17">244</td> <td cl***="xl30">Ssang</td> <td cl***="xl30" x:num="">94</td> <td cl***="xl30">Korenda</td> <td cl***="xl26">Diesel</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A249+1" align="right" height="17">245</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">94</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A250+1" align="right" height="17">246</td> <td cl***="xl30">Ford</td> <td cl***="xl30">94-95</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">300</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A251+1" align="right" height="17">247</td> <td cl***="xl30">GM</td> <td cl***="xl30" x:num="">96</td> <td cl***="xl30">Camaro/Firebird</td> <td cl***="xl26">V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A252+1" align="right" height="17">248</td> <td cl***="xl30">TVR</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A253+1" align="right" height="17">249</td> <td cl***="xl30">Motorsport</td> <td cl***="xl30">79-83</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">330</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A254+1" align="right" height="17">250</td> <td cl***="xl30">Isuzu</td> <td cl***="xl30" x:num="">96</td> <td cl***="xl30">Rodeo</td> <td cl***="xl26">2.6 L4</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A255+1" align="right" height="17">251</td> <td cl***="xl30">Aftermarket</td> <td cl***="xl30">79-93</td> <td cl***="xl30">Mustang</td> <td cl***="xl26" x:num="">5.0</td> <td cl***="xl30" x:num="">330</td> <td cl***="xl27" x:num="">2.95</td> <td cl***="xl27" x:num="">1.94</td> <td cl***="xl27" x:num="">1.34</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.63</td> <td cl***="xl27" x:num="">2.76</td> <td cl***="xl30">7T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A256+1" align="right" height="17">252</td> <td cl***="xl30">Isuzu</td> <td cl***="xl25" x:num="95.5">95 1/2 </td> <td cl***="xl30"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A257+1" align="right" height="17">253</td> <td cl***="xl30">Aftermarket</td> <td cl***="xl30">94-95</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">Cobra</td> <td cl***="xl30" x:num="">310</td> <td cl***="xl27" x:num="">3.35</td> <td cl***="xl27" x:num="">1.99</td> <td cl***="xl27" x:num="">1.33</td> <td cl***="xl27" x:num="">1.00</td> <td cl***="xl27" x:num="">0.68</td> <td cl***="xl27" x:num="">3.15</td> <td cl***="xl30">8T</td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A258+1" align="right" height="17">254</td> <td cl***="xl30">P/Tech</td> <td cl***="xl30"> </td> <td cl***="xl30">Megestar 4X2</td> <td cl***="xl26">Lotus 2.2 T</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A259+1" align="right" height="17">255</td> <td cl***="xl30">Ssang</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A260+1" align="right" height="17">256</td> <td cl***="xl30">Ssang</td> <td cl***="xl30" style="" colspan="2"> </td> <td cl***="xl26"> </td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A261+1" align="right" height="17">257</td> <td cl***="xl30">Nissan</td> <td cl***="xl30"> </td> <td cl***="xl30">4X4 w/1354</td> <td cl***="xl26">Transfer Case</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A262+1" align="right" height="17">258</td> <td cl***="xl30">Ford</td> <td cl***="xl30">98-99</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">V6</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="4"> </td> <td cl***="xl27" x:num="">0.73</td> <td cl***="xl27"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A263+1" align="right" height="17">259</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A264+1" align="right" height="17">260</td> <td cl***="xl30">Ford</td> <td cl***="xl30">99-2001</td> <td cl***="xl30">Mustang</td> <td cl***="xl26">V6 elec speed</td> <td cl***="xl30"> </td> <td cl***="xl27" style="" colspan="6"> </td> <td cl***="xl30"> </td> <td cl***="xl30">Y</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A265+1" align="right" height="17">261</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A266+1" align="right" height="17">262</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A267+1" align="right" height="17">263</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A268+1" align="right" height="17">264</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr> <tr style="height: 12.75pt;" height="17"> <td cl***="xl28" style="height: 12.75pt;" x:num="" x:fmla="=A269+1" align="right" height="17">265</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td> <td cl***="xl30">-</td></tr></tbody></table>
  25. turdmagnet
    turdmagnet
    To moefuzz - I've got a T5 that I can't read the tag due to rust - but the tailstock housing number is 1352-066-927. I was told it came out of a Jimmy/Blazer (Canadian). It is a 3.76:1 first gear ratio and mechanical speedo.
    What does "AWSF" stand for ?? Doing searches on the net I've found guys in the mustang forums, gm forums, and jeep forums that have these casting numbers, so how common/unique would this ****** be ??
  26. Snarl
    Snarl
    If it has a 3.76 first, S10 shifter location, and a mech speedo, just pretend its from a NWC 1986 S10 2.8V6 and be done with it. Order parts for that, and they WILL fit...
  27. Flat Ernie
    Flat Ernie
    Tech Editor
    Moe - I've got a version of that chart in Excel format that I've updated slightly over the years. This is a good spot to dump it, thanks!
    turdmagnet - casting numbers mean almost nothing in T5 world - kinda need the tag or barcode (some GM ******s). You can put it in 1st gear and spin the output shaft once while counting how many times the input shaft goes around & get a pretty good idea which ge****t you have though...
  28. SAL RANDA
    SAL RANDA
    id like to put an early t5 in my 38 chevy cp.does anybody have one for sale help sal randa
  29. HFKND1
    HFKND1
    from Peoria, IL
    Thinking about putting one behind a 348 in a roadster any suggestions on what to look for?
  30. tjm73
    tjm73
    There's not very much of a difference. Lots of 5.0 guys beat them to death in Mustangs. Different gear ratios and a different input shaft.
