Whats this motor
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, May 18, 2008.
  1. panhead_pete
    panhead_pete
    Sorry for the ****py photo but its the best I have at present and if the answer is bovious but trying to ID the motor in this. Photo is probably from 58 or 59. Thanks.
  2. Fat Hack
    Fat Hack
    from Detroit
    Hard to say...looks like a Poncho, Olds or Caddy from what I can tell?
  3. Bodacious
    Bodacious
    As you say, hard to tell from the photo. But if those valve covers sit flat, as it looks like they may, then it's a nailhead of course.
  4. Fat Hack
    Fat Hack
    from Detroit
    Deffinitely not a Nailhead...the heads (exhaust ports) are all wrong. My guess is Pontiac or Cadillac, but you can't really tell from that picture...
  5. kenagain
    kenagain
    from so cal
    just looking at side view exhaust manifolds look like caddys n intake sets up high like caddy carb is generic to olds or cad about 52 53 lady in picture has pink shorts on tho
    Ken
  6. Paul
    Paul
    Editor
  7. ClutchDumpinDan
    ClutchDumpinDan
    Look like center bolt valve covers, I'd vote for Olds.
  8. Rudebaker
    Rudebaker
    from Illinois
    Kind of looks like a Packard 352, they had valve covers like that and IIRC the exhaust manifold layout is similar.
  9. 23 bucket-t
    23 bucket-t
    that is not a motor, that my friend is an engine.
  10. panhead_pete
    panhead_pete
    Thanks guys - courtesy of a member here we may soon have an enhanced image. That body is in my workshop and I'm just starting to plan the build.
  11. RichFox
    RichFox
    If those are center bolt covers that's no Packaqrd
  12. onelo31
    onelo31
    from omaha ne
    looks like my 49 cad 331 they had center bolt valve covers for the first three months then switched to 4 bolt style.the filler/fuel pump neck is in the correct spot for cad also .lots of guys forget or dont know that the early production ohv caddys had these style valve covers! So the comparison to my engine makes my vote for early production caddy mill
    pete
    TWO B'S IN A BUCKET **** IT
  13. JHhj0978
    JHhj0978
    from Youngstown
    im goin to go with a GM motor..im thinkin pontiac cause of the exhaust manifolds, i got a set in the garage that are simiar i believe but then it could be a chevy or olds or caddy or whatever cause they are all pretty much the same on a couple motors..
    goodluck
    jimmy
  14. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    My vote is also on an early caddy. The shared-center exhaust ports that go out off the head combined with the filler/fuel pump located on top of the motor suggest this. Also, if you blow it up in an image-editing program, you can almost make-out the script on the valve covers. The other possibility would be Olds, but the script is wrong and the fuel-pump/filler neck are in the wrong place...
  15. 50dodge4x4
    50dodge4x4
    All I want to know is how kenagain come to the conclusion the lady in the picture was wearing pink shorts? :confused: Is he looking at a different picture then I can see, or does he know something we don't? :eek: :D Gene
  16. 302GMC
    302GMC
    from Idaho
  17. Wild Turkey
    Wild Turkey
    Tried to clean it up a bit-- hope it helps.
  18. Rudebaker
    Rudebaker
    from Illinois
    True.
  19. panhead_pete
    panhead_pete
    Thanks Wild Turkey. Sadly the best image I have.
  20. pitman
    pitman
    If I have to guess, it might be Olds, Caddy or Pontiac. Someone here will recognise the manifold. Certain eras it was the Caddy, other places or times it was Olds.
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That's an Olds exhaust manifold.
