Ok looking for help, channeling a body, how to do it
Discussion in 'The Hokey Ass Message Board' started by Dr.Kerry, May 20, 2008.
  1. Dr.Kerry
    Dr.Kerry
    I am wanting to know the best way to channel a 30 Model A? I've seen it done but have never done it. If someone could give a breif run through it would be appreciated. What steps?? Best way to do it??
  2. Hitchhiker
    Hitchhiker
    opps wrong page hold on.
  3. Hitchhiker
    Hitchhiker
  4. Dr.Kerry
    Dr.Kerry
    Kool, thank you Hitchhiker!!! It's a start in the right direction.
  5. dodgerodder
    dodgerodder
  6. Chris P
    Chris P
    from Tucson
    Just got finished doing my tudor and a friends pickup. If i were you i would start by figuring out how much you want to channel the body. Next work your way through the car and find all the things that lowering the body will effect ie. shifter, e brake, rear suspention...
    next you want to go through and make all of your marks, measurments, and cutlines. (try to remove as much of the old sub frame as possible instead of cutting through it just drill out the rivets and remove the piece) before you start cutting it up you want to weld in 2 or 3 pieces of you tubing structure. use 2x1 and 1x1 tubing to make the new subframe. put in these pieces to the desired higght of the body. now remove the old floor, the body will drop to the hight of the tubing you just put in. now you can go about putting in mor tubing for structure. keep in mind places to mount the body to the frame and places to mount the seats to the body. here is the post i made of the cars we just did. there are lots of pictures
    http://www.jalopyjournal.com/forum/showthread.php?t=266527
  7. Dr.Kerry
    Dr.Kerry
    Great tin work Chris.
    Dodgerodder great link.
