STL guys, Were can I get an alliment done?
Discussion in 'The Hokey Ass Message Board' started by 53dodgekustom, May 23, 2008.
  1. 53dodgekustom
    53dodgekustom
    I was reading the post that Bad Bob made the other day about having trouble getting his front end aligned on his Merc. I need to get mine aligned this week before the rust revival, I don't want the inside tread on my brand new Firestones bald when I get back. (not to mention the safety factor)
    Do you guys know anyone locally that will do it, h***le free and cheap? It's just the stock suspension and steering setup with one coil cut. The front end feels nice and tight but I am sure that there is some worn out parts on it. But I just want it aligned not fed a bunch of **** about how they need to replace everything cause they want my $$$. It's a 53 Dodge and I even have a service manual that tells you the specs and how to adjust everything.
    I would really like to get it done tomorrow, I can wait all day for an opening if need be.
    Thanks.
  2. 53dodgekustom
    53dodgekustom
  3. CLSSY56
    CLSSY56
    I'd take it to Leifers, it's across the street from my house ;) They have tons of the old spec books. Definatly has helped me out a time or two.
  4. Unkl Ian
    Unkl Ian
    What is an "alliment" ? :confused:
  5. Weasel
    Weasel
    Depleted uranium - you know - an ailing element. Or as Sherlock Holmes would have it "allimentary my dear Watson".
  6. Unkl Ian
    Unkl Ian
    OK,now I understand.
    In that case,look in the Yellow Pages under "Alliment". [​IMG]
  7. 53dodgekustom
    53dodgekustom
    Sorry guys, can't spell worth a ****.
    I don't trust Leifer's... Thanks for the input though.
  8. Gunny
    Gunny
    any ****hole in the area with half *** equipment should be able to pull it off...:confused:
