Holley one barrel carb
Discussion in 'The Hokey Ass Message Board' started by gulfwarsubvet, May 24, 2008.
  1. gulfwarsubvet
    gulfwarsubvet
    Changed out the Holley 1909 carb, on the 62 Comet, for a rebuilt Falcon (manual choke) carb model of the same year.
    I got a good rebuild (seems to be a rare occurrence) and after a few adjustments, the car runs great.
    However, the fuel supply line going to the carb is dripping when I hit the throttle.
    I did a search and only found the teflon tape vs. gas post and a couiple others that shot off on tangents.
    What do you guys use for small fuel leaks?
    If possible I want something that's not permanent.
    It's not an emergency, but I dont want to drive it around with fuel dripping onto the exhaust manifold.
    Thanks.
  2. dickster27
    dickster27
    from Texas
    If it's a pipe thread retape it and reistall. If it's an inverted flair simply loosen up and retighten.
  3. gulfwarsubvet
    gulfwarsubvet
    thanks for the input ****ster27.
    Anyone else from the night crew???
