9" Rear end question
Discussion in 'The Hokey Ass Message Board' started by GatorO'dell, May 25, 2008.
  1. GatorO'dell
    GatorO'dell
    I have a ford 9 inch rearend, 5 on 4 1/2 bolt pattern with the new style pattern where the backing plate bolts up for the brakes. I am trying to find some brakes in the junkyard and wondering if anyone knows what year and model fords had this rearend? I have been searching but this is kicking my **** atm. Thanks for any help.
  2. Deuce Roadster
    Deuce Roadster
  3. clays diff
    clays diff
    just look for any ford that has a 9" that has 3/8 holes in the backing plates this has 2& 3/8 back spacing and this should help you. small bearing ford 9" and 8" will not work
    Clay
  4. Deuce Daddy Don
    Deuce Daddy Don
    1957 9 inch came in station wagons, t-birds, rancheros, & fit fine under st.rods without narrowing.-------Don
