Where do you find distributor hardware?
Discussion in 'The Hokey Ass Message Board' started by krooser, May 18, 2008.
  1. krooser
    krooser
    Ever lost the big headed screw that holds down the points? I have several distributors that lack any hold down hardware... where do you find this stuff?
  2. FiddyFour
    FiddyFour
    GMC Bubba might be able to lend a hand... he's a distributor guru... that is unless you need something for a go-kart :rolleyes:
  3. krooser
    krooser
    Thanks Fiddy...
  4. krooser
    krooser
  5. Sealed Power
    Sealed Power
    from TN
    Maybe???
    The individual links won't work search for binding head and truss head machine screws. Might try a button head socket cap screw they sometimes have a larger head on them.
    http://www.mcmaster.com/
  6. ccnova
    ccnova
    You can try this site www.kendrick-auto.com They have lots of distributor parts. Click on the engine parts link.
    ccnova
  7. krooser
    krooser
    Thanks guys...
  8. CadDaddy42
    CadDaddy42
    The Lowe's here has a killer hardware section, and I've found large-headed pan-head machine screws like what you need in their drawers, among other useful bits. Also check the electrical isle - there are some specialty electrical fasteners used in household electrical that fit interesting things like GM ignition module screws, etc. If the hardware / home-store places around you don't have it, check your yellow pages for a place like Fastenal, Copper State, etc. If you have something to show them for a sample, they should be able to find it for you. You'd be surprised what you can get at the hardware store, though.
  9. Try one of the screws on the side of an old electrical plug or switch, might just be the right size.
  10. krooser
    krooser
    More good ideas... am I the only guy who's ever needed this stuff? I remember my boss at Gene's Enco Service back in '64. He told me I was fired if I lost the screws from inside the distributor!
  11. FiddyFour
    FiddyFour
    dont lose em next time dood :p
  12. the first thing i'd do is figure out what size they are...i assume they are small , like 6-32 , 8-32 or even 10-32 or maybe coarse like 10-24. i assume they are also short . maybe 1/2" or 3/8" long? probably panhead
    then a trip to the hardware store and check out their fastener section.
  13. 325w
    325w
    Why not go to the wrecking yard and take some from an old dist. ?? I looked in the garage awhile ago for some I removed not long ago. Their with yours now. ????
  14. kenagain
    kenagain
    from so cal
    what make of dizzy ya talking about mite be some close to ya if we knew which one I second the light switch screw unless it goes in hard
    2 cents worth
    Ken
  15. GMC BUBBA
    GMC BUBBA
    PM me with a address and i will send you a few of each ( points and condensor) I replace them with allen screws when i do a conversion unit for a flathead.:D
  16. TagMan
    TagMan
    I get most of my small hardware from the 50¢ to $1.00 piles at swap meets. Pick up 3 or 4 cheap distributors and you're set to go for a long time.
  17. CadDaddy42
    CadDaddy42
    Was at Lowe's last night looking for a screw, so I looked for the large-head dizzy screws - they are under 'drawer pull screws' in the specialty fastener section. :)
