Rattle Can FlameJob - Design
Discussion in 'The Hokey Ass Message Board' started by SanDiegoJoe, Jun 26, 2004.
  1. SanDiegoJoe
    SanDiegoJoe
    Messing around with a flame design...
    So far... Whatcha think?
  2. nekroman
    nekroman
  3. Nice job!.........the design flows out well.......are you doing the whole car or just what we see?........sent your pic's to another Valiant buddy.........should like it alot!!
  4. general gow
    general gow
    MODERATOR
    I kinda like it. Different. And different is good.
  5. oldchevyseller
    oldchevyseller
    from mankato mn
    how about scallops on the sides and flames in the middle ,see what that looks like
  6. slammed
    slammed
    Great mix of style's. The work follow's the center of hood well. The flames go w/the 'curve' of fener/hood.Like the shade of color as well. Different and unique.
  7. SanDiegoJoe
    SanDiegoJoe
    [ QUOTE ]
    [/ QUOTE ]
    Might do a similar design over the roof too.
    Trying to get something different for Hootennany...
  8. SanDiegoJoe
    SanDiegoJoe
    [ QUOTE ]
    [/ QUOTE ]
    tried it (didn't save the file) and it didn't flow with the lines of the car..
  9. oldchevyseller
    oldchevyseller
    from mankato mn
    [​IMG] how abaout a row of flames across the winshield then streeaming back into a scalloped line maybe equally spaced but short and long ones ,i am too lazy to photoshop [​IMG]
  10. SanDiegoJoe
    SanDiegoJoe
    don't need to see to drive... [​IMG]
  11. Dirty2
    Dirty2
    Looks good what about a side shot.
  12. Bryan
    Bryan
  13. JoeMoto
    JoeMoto
    from Durant, OK
    Flamollops? (flames+scallops) (tm)
  14. haring
    haring
    Personally, Ido not think flames and scallops work well together -- unless there is more of a visual link between them. Right now, they exist separately, without much to justify them together. I realize that this is just a preliminary photochop job, but you also violate the lines of the car in a few instances, and that can be distracting.
    One way to tie them together better is to panel paint the car, using some scallops as dividers and accents, and nesting the flames within the panels.
    To do this correctly, it's probably worth it to spend some money. Obviously metalflake and kandy is what makes something like this pop.
    I'll work up a quick example of what I'm trying to describe.
    -don
  15. haring
    haring
    This looks like junk, but hopefully it conveys the idea.
    Your car is a SQUAREBODY car, as most mid 60s cars are, so you need to acknowledge the blocky lines of the car. Section it off into a panels with radiused corners, then built layers of borders within the panel. The flames become intergral to the border, and everything ties together.
    This kind of paint job is painful to design and excrutiating to lay out. If not done right, it will also look terrible. But done right, with a good eye for proportion, it will look killer. Imagine it with flake and buried under kandy and it would be eye-searing.
  16. heres what this asshole dd in 95 before the "Rat Rod" craze was in vogue
  17. SanDiegoJoe
    SanDiegoJoe
    Well - here is is. The flames still need to be stripped, maybe one night this week...
    </p>
    </p>
    </p> Shane helping out with the template
    [​IMG]</p>
    [​IMG]</p>
    [​IMG]</p>
    </p>
    [​IMG]</p> The wife and Joe Jr.
    </p>
  18. olskool37
    olskool37
    I like the "devil tail" tips on the outter flames,... they got me to thinkin'.....hmmm
  19. slammed
    slammed
    Still look's fine. This lay-out flat work's.
  20. I think flames look good... and I think Scallops look good... but flames and scallops together look like you're trying to jump onto two bandwagons at once.
    I also think that your flames look better than your scallops...
    Sam.
  21. SanDiegoJoe
    SanDiegoJoe
    [ QUOTE ]
    [/ QUOTE ]
    I got the idea for the devil tips on a Shoebox (I think) on a page that had Texas Roundup (I think) coverage... Every lick has a little devil tail on it... cool as fuk...
    I spend WAY too much time on the internet looking at cars, it feels pretty good to go outside and work on mine!
