hello! anyone how knows what engine I have in my 1940 dodge, it is a buissnes cupé. its on its way to sweden so I cant just look. thanks
Probably a 218 c.i. 23" long flathead with a 7.5-1 compression ratio producing about 95HP. See the good folks at the P15-D24 forum for more info on these cars - they do stockers and hotrods there, so long as it is early Mopar
I have a 40 Ply as well...p9 RK...2 door sedan. Currently looking for brakes and rear end options. My car is 100% original.
If you want drum front brakes you can bolt on the backing plates from 65-71 D100 trucks. The seal gets a little tricky but I found a metric seal at a local bearing warehouse that works. The inner bearing race requires a sleeve to convert to the D100 diameter which I made from chro-moly tubing. I used a tandem master cylinder from a 66 F100 with a modified original master cylinder bracket and pedal to retain the stock appearance. Good Luck
Lets see, You bought a vehicle without seeing it in person and don't even know what kind of engine it has? One born every minute......
