Rim sizing help?
Discussion in 'The Hokey Ass Message Board' started by seadevil, May 26, 2008.
  1. seadevil
    seadevil
    Looking for info about what you guys used for rims on an F1 with a Mustang II suspension? Right now I have 5 Ford Magnum 500's steels from the 60's. I just finished installing the larger brakes out to 11 inches and the calipers rub these 14 inch rims. Also need something that wont rub the fenders.
    Thanks
    JD
  2. brandon
    brandon
    you can "clearance" the calipers if they aren't rubbing too bad...done it on some metric calipers to clear some steelies.... brandon:D
  3. seadevil
    seadevil
    Thanks very much and I believe thats what I'll do. These are GM metric calipers and they are barely dragging on the rim.
    JD
  4. brandon
    brandon
    you can use those grinder disk with the sandpaper (can't think of the name right now to save my life....:rolleyes:) basically just polish them till they clear...a thin spacer might help some too... brandon:D
  5. stretch 1320
    stretch 1320
    What the hell is a rim?
