Lifting body off frame
Discussion in 'The Hokey Ass Message Board' started by kerwinq, Jun 1, 2008.
  1. kerwinq
    kerwinq
    from Boise, id
    What is everyone using to lift the body off the frame? I thought about getting an electric hoist that I can bolt to the ceiling but what about setting up a couple of pulleys and doing it manually? Not sure how many times I would need to raise and lower the body
  2. Robert gilbert
    Robert gilbert
    from boston
    I use my buddys . And ive used tie down straps from the beams in my shop one or two inchs at a time on each strap .Check out the pic in my profile
  3. an engine lift and some chains. do one end at a time and set it on long 4 x 4 beam supported by strong saw horses on each side
    what kind of car body? Mode A's , 32-34 four strong guys can lift as already suggested . on my `36 there was 6 of us. on the `49 woodie i'm working on i used an air lift jack in the back and an engine hoist up front
    a hoist from the ceiling sounds great , but make sure your ceiling can take the load
  4. Roadsir
    Roadsir
    Depends on the size of the car and how many people you can round up. To remove a body myself on both my 34 and 47 Ford as I raised the car with the body on the frame, blocked the body with jack stands and 2X8's, lowered the ch***is, I then removed the rear end and slid the frame forward and out from under the car, the reinstalled the rear.
  5. WQ59B
    WQ59B
    >>"an engine lift and some chains. do one end at a time and set it on long 4 x 4 beam supported by strong saw horses on each side"<<
    I did this too: 4x4 beams on 35-gal drums. 1959 Buick coupe shell- no problems.
  6. Deuce Daddy Don
    Deuce Daddy Don
    I agree, get a bunch of strong back buddies & show em' the ice chest full of ice cold suds----------Don
  7. Abomination
    Abomination
    Bring the car to a local shop with a lift, and bring some railroad ties with casters on the bottom.
    Unbolt the body from the ch***is, roll it onto the lift, and lift the body off. Run the ch***is home on the trailer, and come back for the body - lower the lift it's on and put the body on the ties, then roll it onto the trailer and take it home, too!
    ~Jason
  8. BanjoBoy
    BanjoBoy
    Used the engine hoist method.
    two of them
    p*** side and drivers side
    used strong tie down straps wrapped around / underneath body and raised symmetrically / frame rolled forward and wallah.
  9. I use a case of beer. Just call up some friends, do NOT tell them they will be lifting, just tell them you have some beer you need help polishing off and give them a time. EVERYONE will show up that you invite, then when they are all there, spring it on them. Best part is, it will work over and over, every time.
  10. kerwinq
    kerwinq
    from Boise, id
    I would be lifting a 31 sedan, not sure what it weighs, there are no doors/fenders on it right now. Anyone know what the weight might be?
  11. 29Jay
    29Jay
    from Ft Worth
    I do not know the weight, but I used the 4 guys method to load my '29 Sedan body on a trailer when we bought it. We needed all 4 of us to do the job. Then I owed them beer.:rolleyes:
  12. David Savary
    David Savary
    I took the body off of a 65 Impala.(Can you say friggin' HUGE!) The ony tools I used were a bunch of thirsty buddys, a fridge full of cold Carling Black Label and a my wife grilling a bunch of chicken and steak. That big nut bustin' body practically flew off that frame! Oh ya....everyone got 2 Tylenol after dinner too....
  13. KJSR
    KJSR
    from Utah
    37 Plymouth SEDAN, full interior, all gl*** etc. used 3 2x4's (I will use 2x6's next time) and five of my biggest employees. Eveybody survived with exception of the Corona:rolleyes:
    FlatBrokeSpeed likes this.
  14. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I use a cherry picker on the rear and a chain hoist hanging from the main frame rafter of my shop on the front.
  15. cleatus
    cleatus
    from Sacramento
    I took it off the frame by myself, by hand. That was fun.
    To put it back on, I had a party and after everyone was well lubricated I gave it the 'ol "Hey, since we're all here, can you give me a hand with my car for a sec?"
  16. I have done several by myself with a cherry picker and a floor jack, 55 gal' drums and a couple of long piece of steel (3x2,2x2 whatever)to go between the drums when you get high enough to roll ch***is out. Removing rear wheels and rolling rear on jack may help. Always make sure everything is stable, a careless person could get themselves in trouble.
  17. 49ratfink
    49ratfink
    cherry picker, floor jack, lots of blocks of wood and some 2x6's.
    now I do it with my lift.... much easier and faster.
  18. I used my A frame, a one man operation, and it worked great.
    HemiDeuce.
  19. MP&C
    MP&C
    Two engine hoists
  20. kerwinq
    kerwinq
    from Boise, id
    Am I safe in putting straps on the cross members on the body to lift or is there a better way to avoid any damage
  21. northerndave
    northerndave
    from Badger MN
    if you strap like pictured above, just stay above the center of gravity with your center lifting point so you don't end up flipping the damn thing on it's lid. also a real good idea to tie a loop in the strap at the lift point so the strap can't slide in the hook. Would **** really bad if the car shown above got a little heavy on one side & started slipping left or right, could find itself laying on one of it's doors in a hurry... that big "bang" noise followed by a moment of silence & disbelief.... regret etc...
    the sort of thing that would happen to me.
    don't leave those kind of doors open for murfy's law, cause he'll get ya.
  22. rstanberry
    rstanberry
    from terrell tx
    I used 4 x 4 posts and beams at each end with heavy tie down straps. Works great going up, kinda tricky going down because the tie downs want to release all at once.
  23. kwmpa
    kwmpa
    from Pa
    my 40 for i used an engine hoist and 4x4 on jack stands....blocked the body up and rolled the ch***is out...long process by yourself
  24. 65 impala
    65 impala
    it took 3 of us we dragged the sedan out ofthe back of my pickup and put it on a rolling table started doing the metal patch work after that. wasnt that heavy at all
  25. kerwinq
    kerwinq
    from Boise, id
    I am going to be doing it by myself and am trying to find a way to not break my back. Thinking that a hoist mouted to the ceiling with some reinforcement is the way to go. Just wonder how heavy the body is so I know how much I need to add in the ceiling rafters to reinforce
  26. Crusty Nut
    Crusty Nut
    I'm just an average sized guy and I have put on and taken off my 30 tudor several times by myself. I just do one end a little, then the other end a little, ect. It only takes about 5-10 minutes. When things are painted I will get a little help, just so I don't tear up the fresh paint.
    I've used my cherry picker, but it didn't really make the job any easier. The boom was always in the way. The body dolly I use is about 6" shorter than my rolling ch***is. Just park them next to each other and ease it over. It's not a big deal.
  27. Abomination
    Abomination
    Camper jacks?
    ~Jason
  28. I_be_moose
    I_be_moose
    I just lifted the body off my frame Cherry picker and 4 straps to center the load. Solo lift easy....
  29. kerwinq
    kerwinq
    from Boise, id
    That makes it look to easy!! I was thinking I would have to be above the roof line and wasn't thinking of in the window. A picture is worth a thousand words
    Thanks
  30. I_be_moose
    I_be_moose
    I used ratchet straps so I could level the load as I lifted it. makes it easy to adjust the length to the need.
    Tim
