Best Rear End
Discussion in 'The Hokey Ass Message Board' started by tubbsfaith, Jun 3, 2008.
  1. tubbsfaith
    tubbsfaith
    hey guys I have searched and get all kinds of info. Just curious for those of you out there who know. I'm building a 47 chevy I was wondering what the best rear end for that car is? If i could pick any rear for the car which one should it be. I want to eventually run fender skirst so it can't be to wide. I'm leanding toward the 55,56,57 chevy rear if i can find one. Let me know. Thanks
  2. 29moonshine
    29moonshine
    73-77 monte carlo trim all the bracket off the rear end weld on spring perches where needed. they fit good
  3. The same rearends that fit the 49-54s will fit one of these with just a relocation of the holes in the existing perches - 55-57 Chevy, 70-81 Camaro, 70-79 Nova, S10/S10 Blazer 4x4. Overall widths vary some - it's pretty much a matter of how low you want to run the car, what tires you want to run, and what you want to spend on new wheel cylinders - the 55-57 Chevy are a little more money than the others. Also the newer rearends offer more ratio choices and the availability of a limited slip if you want one.
  4. tubbsfaith
    tubbsfaith
    I'm wanting to go low with the car. Which one of these is best for lowering the car?
  5. is this what you meant?:D
  6. publicenemy1925
    publicenemy1925
    from OKC, OK
    I vote for this one too.
  7. diggers4life
    diggers4life
    Way too expensive!
  8. henry29
    henry29
    I have a 65 chevelle rearend in my 48 chevy,its close but I think fender skirts will fit.
  9. Kirk Hanning
    Kirk Hanning
    That rearend would go great in my car....er....truck.....er.....
  10. SakowskiMotors
    SakowskiMotors
  11. tomslik
    tomslik
    i'm running a 59" wide 9" in mine but it's also got 8.5" wheels...
    might want to look at an explorer rear too.
  12. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Why was I expecting that!
  13. 325w
    325w
    IMHO, don't go tri 5. The bearings for those are very high these days. Nova are 8 inch I think.
  14. vintage56
    vintage56
    97-01 explorer axles, if the width works (59"-60" w/ 5 on 4-1/2) gives disk brakes. not that traditional, or practical, but one option I'm weighing for my F-100.
    JML
  15. tubbsfaith
    tubbsfaith
    all helpful info. the blond with the nice rear end may be the way to go! might be able to afford that one.
