NEW demon 98,s .. BG
Discussion in 'The Hokey Ass Message Board' started by skratch, Jan 16, 2008.
  1. Tech @ BG
    Tech @ BG
    It will probably be in the fall before the choke kits are available but a lot of the reports we are getting is that they are starting just fine without them. We have 3 of them on a new small block Chevy package and cold it starts right up with one pump of the accelerator.
  2. Tech @ BG
    Tech @ BG
    They do not have a vacuum line but nor do the 97's we have seen. It might be something that we could make and offer a spacer plate with that provision in it if there was enough call for it.
  3. Tech @ BG
    Tech @ BG
    Kind of a little update since being on here last in that Barry was at the West Coast Custom Show and many commented that they love the look and were reporting good things to him. If you have a conventional small block Chevy we have just released 2 new 98 Triple Deuce Intake packages with one being old skool and the other a little more modern. I have a couple of pics and will see if I can figure out how to post them up.
  4. Tech @ BG
    Tech @ BG
    Let's see if this works.
  5. Tech @ BG
    Tech @ BG
    This is on one of our test vehicles and here it is from the other side. The packages will include everything from the intake gaskets to the carburetors with you supplying your own air cleaners. The Old Skool package has the red fuel lines and chrome fuel block while the other kit comes with a billet fuel rail .
  6. Retrorod
    Retrorod
    I still think you guys should make that "98" a replacement for the Holley 94 like our roadster has on it's 1951 8BA.....a stock Holley 94. All you need to do is make a model with right side throttle linkage and a vacuum port for the old "Load-o-matic" vacuum advance distributor..........and I'd buy one today.....maybe two of them just to have a spare.
  7. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    I've included pics of my carb. All I can see on it is a stamp "model 7RT and the ford script on the other side. Not a 97, but you can see the black vacuum advance line. So is it much of an issue of I disconnect the vacuum addvance line going to the distributor? How did they handle advance with the 97?
    [​IMG][​IMG]
  8. Flat Ernie
    Flat Ernie
    Tech Editor
    If you've got the stock load-a-****ic distributor, it's an issue. Most folks tossed the distributor in the bin when upgrading carbs (usually adding more than one - otherwise, no reason to change your 7RT)
  9. You cats seem to be forgetting two things.
    One, I don't thonk that these carbs CAN be made to look like 97s, 94s or something original anyway. Ever heard of Patent Laws? BG have loosely based their range of carbs on the Holley designs BUT they are not identical and Im betting this is by design due to Patent Laws that are applicable. I stand corrected if I am wrong.
    Two, a lot are forgetting that we are fortunate that a manufacturer feels strongly enough about it so as to ga about making new carbs with a trad feel altogether. And that goes for ALL performance parts. I think we've been spoiled for choice esp you guys Stateside.
    Now that's something our hot rodding Pioneers had ZERO of. So think of that next time ya'all wanna rag on a new product before you've even tried it.
    THIS my gearhead buddies IS the Golden Age of rodding too....we just don't know it yet. We will later in life but we can't see it yet. How many of our hot rodding pioneers actually termed THEIR time the Golden Age of Hot Rodding...? Im betting NONE, they thought it was just something they all enjoyed and did and did'nt think of it as being a "Golden Age" . Most of them would have killed for better GO FAST parts and this has been discussed many times on here.
    I say good luck to any person who has a go at making speed parts - with a finicky market like this, some may think you're nuts to give it a go hehe.
    For the record, Id run em on a daily or a closed hood car because yes, I do prefer the older look of 97s or 94s. But that don't mean I hate this product and nor does it mean that it does'nt have a rightful place in the market. At least you have a choice. Some people don't have that choice.
    Its all about opinions - lets not forget that.
    Rat
  10. Muttley
    Muttley
    HAHAHAHAHA.................yeah sure. I guess the "Golden Age of Hot Rodding" is rusted out thirty thousand dollar Deuce bodys and $4.50 a gallon gas. I'll bet the the old guys sat around and couldnt wait for the junk yards to dry up so they could spend weekend after weekend searching swapmeet after swapmeet (and coming home with nothing) for a part that thirty years ago they would have tripped over at the local s**** yard. If this is the "Golden Age of Hot Rodding" some one loan me their time machine..................I'll set a course for the Silver Age.
  11. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    I just got home with my truck being towed because that friggin carb decided to pour as much gas down the intake as possible. Somebody please tell my carburetor that spark plugs don't like to swim in gasoline.
    I'm ordering a demon 98, no question. And aside from the demon 98 stamp on the front, I actually think it looks better than the original carbs anyhow. I know I know, it doesn't look "retro" but if you actually look at a demon 98, it has a sleeker more curved look as apposed to a more angular boxy look of the 97/94. The way I see it is a 97 might be period correct but a demon 98 suits the overal look of a 50's car/pickup better. And it don't leak, which suits me fine. And regardless of looks, I'd rather drive my truck daily than trailer it to a car show anyhow :)
    I know with a demon 98 my intake manifold will stay nice and clean looking, but I've never seen an intake with a 97 on it that didn't look like the carb pissed itself.
  12. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    Subscribing to thread...
  13. bigdaddy55
    bigdaddy55
    from Allyn, WA
    I'm going to put two on my sixbanger w/fenton of offy intake.
  14. krooser
    krooser
    Where are you gonna get your distributor va***m from?
  15. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    I'm not. I'll change the distributor out for one with a mechanical advance.
  16. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    hah! wouldn't you know it. Small problem. My original carb had the throttle linkage on the p***enger side, while it appears the demon has it on the driver side. I think the throttle shaft rotates opposite as well. Any ideas how to work around this?
  17. Jdee
    Jdee
    I don't like the logo on the front, but think I might
    have found a work around for my car. LOL
    Jdee
  18. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    On their website, bg touts the demon 98 as a replacement for the 94 and the 97. I picked up one, and didn't realize until I got it that the linkage was on the oposite side as my 94. But looking at pictures of 97's I think the demon is oposite to that as well because it looks like the 97's and 94's had the linkage on the same side (p***anger). I'm with you on the vac*** port though. I'm going to fabricate a simple "cross-over" linkage and swap out a distributor with a centrifugal advance like an msd. BG says that you need to set your initial advance at 10 degrees instead of 5 as normal, so you'd have to adjust your distributors advance as well, which I don't know how to do on those old stock vacuum advance distributors, which makes a distributor swap even more compelling.
  19. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    The vacuum port has to be above the ****erflies...
  20. Tech @ BG
    Tech @ BG
    At this time there are no plans to change the baseplate machining process to incorporate this. Most of the older stuff used manifold vacuum to begin with which is what we kept in mind when originally designing these.
  21. Casey
    Casey
    hell just squirt gas all over them and they will blend in !
    and you could sand the demon logo off .
    Holley is really missing the boat not making a modern version of the 94`s
  22. jd2a7x
    jd2a7x
    from seattle
    well i guess all i have to say is i drive a 63 thunderchicken with a factory ford tri on it and i just recently got a 6x2 edelbrock for my 406 and i have to say i honnestly wouldnt consider running anything other then the demons for the pure and simple fact of function and the most important fact SPEED!!! MORE CFM GO FAST EVERYWHERE!!!! i may be just a young buck but it seems to me a lot of so called traditional true hot rodders may be losing their way. dont get me wrong looks are very important but ive always considered being faster then the kid down the street the more important factor in why i absolutely love hot rodding. my friend has a 39 for pickup that "traditonal" and i leave him for dead granted my car isnt entirely period i but i havent found a single person yet that knows the tape deck isnt factory or that a 63 hardtop didnt come with a tripower. lets be honnest its all about the "WOW" factor rarely does anybody walk up to a car and go sorry your car ****s because its not period correct and if you really want to nit pick it and be a **** unless it 100% absolutely original there is no period correct because your all using new modern screws nuts and bolts so...i guess what im getting at is cant we all just get along?
  23. jd2a7x
    jd2a7x
    from seattle
    P.s. Thats how i roll
  24. Flat Ernie
    Flat Ernie
    Tech Editor
  25. jd2a7x
    jd2a7x
    from seattle
    my opinion is my opinion i said nothing offensive everybody else here seems to feel free to voice thier opinions i did the same if you dont like it go complian on the internet somewhere else where people might care last time i checked the whole point of a fourm is to provoke disscussion and debate
  26. Muttley
    Muttley
    FYI dude, when a well respected HAMBer like Flat Ernie gives you advice on how to conduct yourself on the HAMB, take it. It'll save me from having to post umpteen dozen Liberace pics.
  27. zman
    zman
    from Garner, NC
    You are free to leave, and I think you went from "young buck" to "snot nosed" in under 4 posts.
  28. Dreddybear
    Dreddybear
    You're a cl***y piece of work, kid. Way to bash our beloved Flat Ernie your first day out. Oh, and you must be pregnant because you're missing your periods. Grow up. Respect our community and we'll respect you and treat you fairly. If you want to act like a **** and tell one of our most prestigious and helpful members to go "complain somewhere else", then you can go screw yourself. You don't know what you're talking about or who you're talking to.
  29. Vintage Warrior
    Vintage Warrior
    from TX
  30. Vintage Warrior
    Vintage Warrior
    from TX
    Interesting marketing considering this isn't a carb most originality minded guys would run and it should attract retro rod guys with a modern component mindset. I haven't gotten around to buying yet, but I plan to run them in a tri-power config on a slant 4 Pontiac with an Offy log...
