Chassis swap for '50 Olds- what works??
Discussion in 'The Hokey Ass Message Board' started by rdstr31, Feb 20, 2004.
  1. rdstr31
    rdstr31
    from Ney, OH
    I've got an opportunity to pick up a '50 Olds body really cheap- it's almost a basket case. I'd like to make a mild custom daily driver out of it, but I don't wanna spend the money updating the original ch***is. Does anyone have an idea what late model ch***is would fit under this car? I don't expect it to just drop on top of the new ch***is, and I'm not afraid of cutting up this car to make it work. Any help would be appreciated! I did see that post a while back of the guy who built his ride in 3 weeks- that's the same thing I'm looking to do, but I can't find it now! Any help??
  2. flying clutchman
    flying clutchman
    in my local auto trader i saw a 1950 oldsmobile for sale. it was sitting atop i think it said a 80's cadillac ch***is. they only wanted 1 grand for the car.
    diego
  3. deathmobile
    deathmobile
    BTT
    any other ideas?
  4. art.resi
    art.resi
    How would a s 10 measure up.
  5. chaddilac
    chaddilac
    Why don't you just clip it and put a late model rear axle in it. It'd be a lot of work to get another ch***is to fit, plus cutting the floor pans out and making them work too. yikes!
  6. art.resi
    art.resi
    Thats the best way and what I would do also.
  7. It depends on the model. The 88 and 76 need a 119.5" WB ch***is - mid-80s GM fullsize is that long, but they're too wide, the tires hit the fenders on turns. An S10 extended cab might do the job. They're easy to shorten or lengthen as needed.
    But if the stock frame is there, I'd stick with it before a complete swap. The rear springs will take a lot of common rearends bolt-on and the front could be clipped as suggested.
  8. Do the stock frame if you can.
    I like the olds fastbacks.
