Brake/Clutch Pedal Advice Needed.....
Discussion in 'The Hokey Ass Message Board' started by brett4christ, Jun 10, 2008.
  1. brett4christ
    brett4christ
    I need your advice on which brake/clutch pedal ***embly(ies) will work best on my 1946 Chevy PiCoupe. I originally had an early 60's truck split master cylinder and hacked pedal ***embly, but have added S10 disc brakes on front with 55 Chevy p***enger rear drums. For ease of fabrication, I think I want to use a Hydraulic clutch slave cylinder.
    Can I stay with the same master cylinder setup, or is there something much better for my application? I want to keep the firewall as clean as possible, but the above M/C would be acceptable as a period application.
    Help me shift and stop safely! Any advice is welcome!
  2. brett4christ
    brett4christ
    Bump! I really could use some advice, guys!
  3. Halfdozen
    Halfdozen
    Go with a dual master cylinder.
    Mazda B2000/ Ford Courier small pickups had nice little cast iron clutch cylinders, using them in my '40. Lots of the later stuff is plastic, wouldn't go there.
  4. ratso575
    ratso575
    I used the set up in my 37` p-cup out of speedways catalog for a circle track car ....
    single clutch and dual master set -up .....the clutch uses a hyd. throw out brg. ....... works flawless , and very compact in design .....
  5. fab32
    fab32
    You could always got with one of the behind firewall units from Kugel. That way your firewall is clean.
    Frank
