Holley 94 thread and jet question
Discussion in 'The Hokey Ass Message Board' started by Traffic Violator, Jun 15, 2008.
  1. Traffic Violator
    Traffic Violator
    from Bangerland
    Can someone please tell me the thread on the vacuum port of a 94 Holley as I want to block it off with a suitable plug.
    Also any suggestions on a start point for jets & power valve to run it on a stock model A banger motor?
    thanks:cool:
  2. dickster27
    dickster27
    from Texas
    The thread size for the vacuum port is 3/8"-24. A good jet starting point would be 39-42. A 65 power valve I think will work fine.
    Montana1 likes this.
  3. Traffic Violator
    Traffic Violator
    from Bangerland
    Thanks ****ster, the jets currently are 59's with a 65 PV. I'll order up some smaller alternatives.
    As a second thought, i bought a pair of 94's with the secondary carb minus idle circuit and choke. If I get a Y adapter from charlie price how would i jet the pair? or would one realistically be better as a dummy on the stock banger?
    thanks Vince
  4. dickster27
    dickster27
    from Texas
    Vince, I might be critisized for this answer but I would try one hot and 1 dummy to start with on the stock 4 cyl. I think you will overwhelm that little engine with 4 times the fuel all at once. If it runs good on one maybe include the 2nd one but I would suggest on progressive linkage so you will have some RPM's going before you dump the extra load.
    Actually, I have one of the adapters you are speaking of in stock. If interested PM me and we can talk.
