Ford SD-EFI fuel pump questions
Discussion in 'The Hokey Ass Message Board' started by Ferguson777, Jun 17, 2008.
  1. Ferguson777
    Ferguson777
    Plse tell me if I’m on the right track here plse;
    Engine is a 1990 Ford 5.0L with SD-EFI which I believe wants 30 to 45 PSI
    Fuel tank is an 84 full sized GM van with non-in tank sender
    <O:p</O:p
    I want to run an in-line electric fuel pump. Not an in-tank model.
    <O:p</O:p
    I’m looking at the following fuel pumps –all have 3/8 hose barb inlets and outlets unless otherwise noted;
    <O:p</O:p
    Accel # ACC-75701 (Summit price $249.95)
    43 GPH @ 60 PSI
    <O:p</O:p
    Accel # ACC-74701 (Summit price $174.95)
    43 Gph @ 45 PSI
    <O:p</O:p
    MSD Ignition # MSD-2225 (Summit price $94.70)
    43 GPH @ 85 PSI
    Inlet 3/8, Outlet 5/16 - both are hose barb
    Summit # SUM-G3138 (Summit price $79.95)
    Other than both in and out being 5/16 hose barb, appears
    to be the MSD unit
    <O:p</O:p
    Holley # 12-290 (Summit price #165.95)
    67 GPH @ 100 PSI
    <O:p</O:p
    BTW – Engine puts out 250 to 275 HP max.
    <O:p</O:p
    Is there any of the above that I should not use and why?
    <O:p</O:p
    Do I need to run a fuel pressure regulator as well?
    Thanks.<O:p</O:p
  2. Ferguson777
    Ferguson777
  3. david
    david
  4. mustangsix
    mustangsix
    If you're only making 275 hp you should only need between 20-25 gal/hr of fuel. To ensure you have enough capacity, any pump that can push 40 gal/hr should be enough. 3/8 fuel line will be plenty. Just to be safe, use the same size for the return.
    HP/BSFC (usually between .4 and .5 for normally aspirated engines) = lbs per hour of fuel. Divide that by 6.5 lbs/gallon to get GPH estimates.
  5. Malcolm
    Malcolm
    from Nebraska
    Another good site that might have the answer to your question is:
    www.Corral.net
    Malcolm
  6. fast Ed
    fast Ed
    Most of those you have listed are likely repackaged Bosch pumps. You could buy a generic one through a parts store for less $$ I'm thinking. And yes, you will need a regulator, but the OEM one on the Ford fuel rail should be fine.
    cheers
    Ed N.
  7. Ferguson777
    Ferguson777
    Guys,
    Thanks very much for the responses and the information.
    I appreciate your help.
  8. cool57
    cool57
    NAPA makes a good generic external pump. I'm using one on my EFI 5.0. I can look up the part number tomorrow, but the NAPA guy seemed to know what I needed when I went looking. Must be a common EFI application.
