Removing rain gutters
Discussion in 'The Hokey Ass Message Board' started by Baja Bandido, Jun 17, 2008.
  1. Baja Bandido
    Baja Bandido
    Hello everyone,
    Hopefully you can help out a newbie to the hamb. I ran a search for rain gutters but only found threads on repairing or making rain gutters. How would you go about removing them since they seem to be a seam. I'm actually removing them off a off road race truck. it's a Ford Bronco. So would I cut out small sections at a time and tack those in and keep going along until it's completely removed or is there a better way to handle this type of project?
    Hopefully you guys won't be offended that this isn't a hot rod rig but off road sites never address these types of sheet metal questions.
    Any pics would help.
    Thank you.
    Chris
  2. GREASEMONKEY72
    GREASEMONKEY72
    do sections at a time and make sure not to over heat anything so you dont warp the roof
  3. pimpin paint
    pimpin paint
    from so cal
    Hey Chris,
    I'd use a cut-off disc, and just cut the gutters flush with the roof
    panel sides. Be sure to cut out any rust, and replace any cut out
    metal , prior to welding up the area. Small tack welds a foot a part,
    than six inches, than three, than one, wil insure little warpage of the
    roof panel.
    S****ey Devils C.C.
    "Meanwhile, back aboard The Tainted Pork"
  4. toddc
    toddc
    Make sure the area you are going to weld is clean. My Poncho had the gutters leaded on. That was a royal pain to fix.
  5. Baja Bandido
    Baja Bandido
    Thanks guys for the advice. Any pics? I've already taken a wire wheel to the rain gutters and so far little to no rust.
