took 'er around the block a couple times, temp came up to 195 and stayed there, at an idle oil came down to 28 psi. some valve noise, I will check them tomorrow. I think this will be the setup for a while. here she sits purring away Paul
You have got to have some of the Coolest Damn rides on the HAMB PERIOD!! That Thing Looks ***s!! Hows the little modified you are building?
Fat Hack, that there carc*** became a rickshaw when it donated its windshield/cowl sheet metal to the coupe Rocky, it do! Upchuck, huh? Nekroman, thanks, not much room under the car, hence the side-pipe look... Barn-core, I guess it could be considered a female devil dog? Tuff Tin, thanks, sometimes she is as cold as ice but once in a while she warms up and the juices start flowing, the screaming starts and the fireworks are spectacular! Evel, Thanks man! UptownJoe, got a nice little lope and winds up tight! SIXOCAD, intake number four and carbs nine and ten, but whos counting? RatPack, thanks! bufordtjustice, thanks! SamIyam, thanks, yeah, I squirted some black at it.. Marcus, thanks, modifieds on hold while I try to get this thing back on the road. Greezy, thanks! Paul Windshield, whacha doin up so damn early on a Saturday? today? I'd take a rootbeer! I need to road test Paul
