Removing carbon from pistons???
Discussion in 'The Hokey Ass Message Board' started by Stewed, Jun 30, 2008.
  1. Stewed
    Stewed
    I have a set of SBC 327ci .040 over TRW forged pistons I want to clean up and sell but cant figure out the best way to clean the old carbon off the top of the piston without messing up the machine marks from where they were made. I soaked them in mineral spirits for a week and all the bad stuff came off but it still has a thin coat of carbon over the top. I dont want to risk a wire brush giving them that screwy half polished look!
    Chemicals? Acid?
    Thanks!!
  2. Jethro
    Jethro
    If you have access to a carb dunk tank, that will clean them up real nice. Let them soak for a couple hours then rinse real good with lots of hot water. The spray stuff doesn't work as good as the dunk stuff.
  3. oldsman71
    oldsman71
    use oven cleaner,but rinse it off good start with a few minets, but always rinse,be careful not to leaveit on yer hands long!!:D
  4. VonMoldy
    VonMoldy
    from UTARRGH!
  5. KJSR
    KJSR
    from Utah
    Loc-***e spray-on remover works great. We use it on our aircraft engines....
  6. bryan6902
    bryan6902
    I use gasket remover spray. Let it sit for awhile, it will start to dry out and get an orange peel look to it. Then get some good rubber gloves on and scrub em off under hot water in the sink with a green scotch brite pad.
  7. 34underglas
    34underglas
    I have bead blasted 327 pop ups before with good results
  8. chaddilac
    chaddilac
    Me and a buddy just did the same thing to a 350, we pulled the heads, and used brake cleaner and a wire wheel on each piston. I rotated the ***embly and he hit it with the cleaner and wheel. cleaned up nice.
  9. BigChief
    BigChief
    Permatex spray on gasket or paint remover works well. Hit it, let it sit, scrub it with a scotchbright, hit it again.....repeat as necessary. Clean the ring grooves out as well. Using very fine gl*** shot (feels like baby powder) afterwards will make them look great for the photo-op.
    ....also, considering what they are worth (or not) as used pistons its probably time/money better spent on just selling them as is and let the next guy clean them up. The difference in price between clean and dirty used pistons isn't that much. Most engine builders shy away from used pistons unless they know the history of the part. Since these are relatively cheap pistons to begin with they'll be hard pressed to justify the expense of taking a chance on used slugs vs just buying a new set and knowing what they've got.
    -Bigchief.
  10. Stewed
    Stewed
    Thanks for the idea's, I have a can of carb cleaner in the garage and didn't even think of it till now. It worked wonders on the Edelbrock I did a few weeks ago. If that doesn't work I'll try somthing else from this post!!!
  11. Dyce
    Dyce
    If you dip them in carb cleaner and rinse with water, make sure you oil the pins when you're done. The pins can get tight with water and no oil. And don't bead blast them if you still have the rods on.
  12. Black Magic
    Black Magic
    You sided it man that stuff works it will take carbon off any metal.
  13. I use my Jet-Washer with lo-foam aluma-scrub in it. Go to a machine shop that has one with this chemical in it. They come out clean and shiny as hell>>>>.
  14. Johnnyzoom
    Johnnyzoom
    from Florida
    Simple Green and an elelctric toothbrush.
  15. KJSR
    KJSR
    from Utah
    Yeah, most of my guys are in a hurry....were fighting a war out there! It works the fastest with the cylinders in place.
  16. McGrath
    McGrath
    If they are out of the motor that was in that Henry J, they should be considered family jewels. Or is that not the same motor thats been in there for the last 40 years?
  17. HOT ROD DAVE
    HOT ROD DAVE
    this works great !
  18. 7"Chop
    7"Chop
    from Denver
    Unless you are planning to sell them to Al Gore does it really matter ?
  19. Acetone works great!!!! Doesnt eat into the auminum like oven cleaner can.
  20. Bodacious
    Bodacious
    Just make sure when bead blasting pistons that you never blast below the ring lands.
  21. Stewed
    Stewed
    Not the same man, that one is in storage. These are from a 327 dad stuck in it a few years back to keep from having to fund a full rebuild . That is why I am trying to sell these to fund the machine shop bill, and parts bill, and the carb rebuild bill, and the torque converter bill and so on----------------
    The carb cleaner(dip) worked fine but took a long time(over night). I believe I will hunt the Loc-***e stuff mentioned above.
  22. McGrath
    McGrath
    Good thing you Elevator guys make lots of money...:D
  23. 37FABRICATION
    37FABRICATION
    If they're still in the motor, just pour a little black powder in the plug holes, ign. on and voila_no carbon!:)
  24. Stewed
    Stewed
    No money here, all on the barter plan, I will be painting every house for every family member related to the man who owns the machine shop.. Besides since when was minimum wage "LOTS OF MONEY"
  25. Do you have an exact name and any idea if it's available over-the-counter at Napa and such? I made a few calls and searched Loc***e's web site and didn't find it.
    Thanks,
    Kurt
  26. KJSR
    KJSR
    from Utah
    Loc***e item number 34663. It's called "Loc***e chisel gasket remover". Not too sure if Napa has it buts everywhere on-line.
