Top Ten Fab. Tools
Discussion in 'The Hokey Ass Message Board' started by Shrek, Jul 8, 2008.
  1. Shrek
    Shrek
    Alright with there being such a diverse group of fabricators collected here let's get yalls opinion on what your top ten fab tools/equipment are in your shop. I'm talking anything you use to shape, burn, cut, bend, tweak and style that metal into submission.
  2. May Pop
    May Pop
    Torch hammer big vise and a hillbilly socket set [both sizes std and metric]
  3. docauto
    docauto
    from So Cal
    MIG, Torch set, Big Vise, Big anvil, 1/4" air grinder, 4" electric grinder, sawsall, lathe, mill, hand tools.
    that's 10.
  4. 37FABRICATION
    37FABRICATION
    Ten sizes of hammers.
  5. publicenemy1925
    publicenemy1925
    from OKC, OK
  6. SinisterCustom
    SinisterCustom
    Railroad rail...........@ 1' long.....
  7. different diameters of pvc pipe with round and flatcaps on the ends...cheaper than the real deal
  8. hammers, dollies, MIG, plasma cutter, big vice, anvil, die grinders, 4-1/2" grinder, c-clamps, 3" cutoff wheel, files, torch, --- oops that's more than 10.
  9. ELpolacko
    ELpolacko
    #1 lots of hand tools, box end wrenches, sockets, ratchets
    #2 files, good ones
    #3 air compressor, at least 5 hp
    #4 oxy/acc rig with a good selection of tips
    #5 20 Ton Hydraulic press, even a ****py Harbor Freight one.
    #6 floor jack
    #7 good quality jack stands and lots of them
    #8 4.5" and 7" angle grinder
    #9 Chain
    #10 a good level and angle finder.
    With those tools, you could build or repair just about anything.
  10. zman
    zman
    from Garner, NC
    4.5" grinder with cut off wheel
    vise
    MIG
    TIG
    body hammer
    grinder
    torch
    shaping hammer and bag
    welding fab table and clamps
    order depends on the project.
    But these are the most reached for.
    El Polacko has some good ones on his list as well, had I seen his list first I may have changed what I came up with, but this is what came to mind
  11. metalshapes
    metalshapes
    Tape Measure.
    a couple of Rulers.
    Calipers.
    Anglefinder & a couple of long Levels.
    a Scribe, and a couple of Sharpies.
    And then...All the rest.
  12. INXS
    INXS
    2 tape measures cause I always temporarily lose one.
    Silver Sharpies
    cereal boxes
    scissors
    paint marking pen
    blue layout dye
    scribe and dividers
    Beverly shear
    oxy acc setup
    MIG
    In no particular order
  13. paco
    paco
    from Atlanta
    I think:
    TIG & MIG welders
    Plannishing Hammer
    Slip Roll
    Beater bags & hammers
    Brake & shear
    Plasma cutter
    Loads more....
    But the thing I really need that I don't have is....... MORE SPACE for the tooling I have!!!!
    Paco
  14. theHIGHLANDER
    theHIGHLANDER
    What ELpolacko said with my changes:
    Metal cutting vertical bandsaw
    Big compressor (10hp 35cfm)
    40" slip roller
    48" metal break
    24" step/bead roller
    50# shot bag
    25# sand bag
    Good sharp drill bits
    And speaking of drill bits, a set of Roto-Broach cutters is like heaven in the shop. Re-grinding old bits into sheetmetal bits ain't too bad either. And really, the list should be top 50...or 100!
  15. toddc
    toddc
  16. Tony
    Tony
    Safety goggles....
    Yeah i know, not at all what you meant, but after having some metal in my eye last winter it has become a natural thing for me..
    hard to fabricate anything if'n ya can't see.
    I'll also add, or agree with some other's....
    A good 220 welder and band saw..
  17. zman
    zman
    from Garner, NC
    tape measure and sharpies shoulda made my list as well...
  18. punkabilly1306
    punkabilly1306
    from ohio
    i really wish i had his problems LOL
  19. Tony
    Tony
    I'll add another..
    Poster board..Yep, the kind you get at craft stores. Works great for making templates..
  20. Clark
    Clark
    4 1/2" angle grinder has to be the #1 tool in my shop. I now have 2 one for cut off wheels and another for flap wheels. Less time spent changing wheels.
    Mig
    Plazma cutter
    air powered 2" angle sander
    verticle band saw (don't use the chop saw much since we got it)
    drill press
    belt/disc sander
    Big Bertha C clamps (the good ones with the sliding arm)
    all the hand tool
    Maybe the last one should have been first....your friends!
    Clark
  21. zman
    zman
    from Garner, NC
    I like the FridgePack cardboard from soda's. We go through enough at the shop that I always have some around.
  22. mac762
    mac762
    This might sound cheesy as hell, but the mind is the most vital fabrication tool. I am very fond of the Mig welder and angle grinder. My tape measure and steel sqare with the 45 degee angle on it is very important. Clamps C and VIse styles are loved as well.
    My drill and a 5 pound sledge are other favorites. Sharpies bring me up to ten.
    Top 4 would be welder, grinder, clamp, tape, square.
  23. Homemade44
    Homemade44
    These are the big tools used most in my shop.
    Mig welder
    Pullmax with tooling
    Bead roller with dies
    48" stomp shear
    48" brake Magnabend
    Shrinker and stretcher set
    Band saw
    English wheel
    Burr King belt sander
    Air compressor 5 hp
    For the small tools:
    Layout tools
    Hammers and dollies
    Stump
    Beater bag with stand
    Hand shears Left, right and straight cut
    Files
    Vise and clamps
    Normal set of hand tools
    Good steel work table
    Electric 4-1/2" grinder
  24. arkracing
    arkracing
    I've only seen it mentioned once above, but I think the Beverly Shear is great!!! As soon as I can afford to get the B2 it will be my next tool purchase
    http://vansantent.com/sheet_metal_machines/beverly_shear.htm
    A good - big table
    I'll second the Belt sander as well - the 4" jobbies that are like $100 work well for most things.
  25. paco
    paco
    from Atlanta
    Hey punkabilly1306,
    You don't know the 1/2 of it......
    It is a big issue as I also have a southbend 6' lathe, a Powermatic 1150A drill press, a Packard Machine Bench top mill, a Lakewood industrial fan, a Snap-On KR1000 & top jamned full of air cutting, drilling, hammering tools plus some hand tools I've collected from the snap-on guy over the last 20 years or so....
    Plus I keep my motorcycle lift table in the garage too.
    So yes - space at my 2 3/4 garage, attached to my house, is a bit cramped. I wish I had a detached garage like some of the guys on here....
    Space.....if I only had more space......I'd post pix of my garage but I've got so much junk in it I'm kinda embaressed!! When I get it cleaned up I will.
    Paco
  26. novadude
    novadude
    I can't fabricate anything to save my life, but I am trying to learn.
    Having said that, I can't believe it took until post #24 for someone to mention L & R offset hand shears. :)
    But what if my friends don't build cars? :eek: Time for new friends! LOL
  27. seret
    seret
    the floor
    torch
    tig
    beverly shear
    sand bag
    oxygen tank cap
    power hammer
    english wheel
    vise
    louver punch
  28. Topless Ford
    Topless Ford
    Beer, a vice, 4" grinder, welder, hammer and dolly set. That is what I have so far.:)
  29. NTAPHSE
    NTAPHSE
    1. angle grinder
    2. sheetmetal shears - L, R, straight
    3. MIG
    4. Harbor Freight step drills
    5. body saw
    6. horizontal bandsaw
    7. hammer and dolly set
    8. combo disk/belt sander
    9. vice grips
    10. bench vise
