Nail head flywheel interchange?
Discussion in 'The Hokey Ass Message Board' started by El Loco Worm, Apr 28, 2008.
  1. El Loco Worm
    El Loco Worm
    from oklahoma
    I've got a 322 buick nailhead and was wondering what all flywheels will work on it. It's going to have a manual trans. Thanks for any info or nudges in the right direction.
  2. zman
    zman
    from Garner, NC
    264/322 only....
  3. Judd
    Judd
    I think all 53 to 56 will fit but I think there are different clutch sizes. There is a big and little trans and bellhousing. The bell for the big trans can be modified fairly easly to fit a Chevy 4 speed. A 56 Buick pilot bushing will work with a Chevy input shaft.
  4. tstellhorn
    tstellhorn
    This is an old thread, but...
    The information I've found is that the 322 flywheel is NOT the same as the 264, and therefore not interchangable.
    Todd
  5. phiftybuick
    phiftybuick
    from NM
    ------that's correct, Todd; The 264's are internally balanced (no vibration damper on the crank pulley) and the 322's externally.
