extra gauges, how have you mounted them?
Discussion in 'The Hokey Ass Message Board' started by 49anglia, Jul 13, 2008.
  1. 49anglia
    49anglia
    Got a single 2" guage i need to fit somewhere, no way im cutting the dash.
    Lets see yours, i need some ideas.
    Thanks.
  2. FiddyFour
    FiddyFour
    well, lets see what you have, and where you want it to go... might give us something to work with
  3. hang them in a small panel bellow the dash...here is a `32 i did
  4. 49anglia
    49anglia
    bad pic of the dash
    The parcel shefl on the drivers side is already ocupied.
  5. 49anglia
    49anglia
    the gauge
    Although mine looks a little older.
  6. chopper99
    chopper99
    The 56 Olds dash I put in my shoebox Ford had only a fuel gauge and everything else was idiot lights, so I hung two gauges under the dash for oil pressure and water temp, I also connected the idiot lights, since they may catch your attention faster, if there is a problem.[​IMG]
  7. 49anglia
    49anglia
    I have idiots lights but the oil one isnt wired yet. I mounted them in the front of an old cherry boot polish box, put the relays and fuses inside and bolted it to the parcel shelf behind the steering wheel.
    I'd like to come up with a nice panel to mount it in, i guess there's not much choice.
    Either hang it under the parcel shelf or maybe in some kind of bullet pod ontop of the parcel shelf?
  8. 49anglia
    49anglia
    what about on the tunnel infront of the shifter?
  9. chopper99
    chopper99
    That would work, as long as someone doesn't step on it.
  10. willys33
    willys33
    from New Mexico
    What I did was go to a local muffler shop and get two inch exhaust pipe, had them expand it a bit and then welded a back flange on then weld it into the dash. Did five gauges this way and painted the inside flat black.
  11. Ranunculous
    Ranunculous
    Nice work! Great interior!
  12. whid
    whid
    damn thats one fine dash.good job.......................dave
