Why is my fuel guage grounding out?
Discussion in 'The Hokey Ass Message Board' started by vintagered13, Jul 15, 2008.
  1. vintagered13
    vintagered13
    I'm using the original fuel gauge for my truck, I ran a new wiring harness and and put in a new tank with a sending unit. But once I got everything hooked up I noticed that anytime the gauge cluster is hooked up and touches a grounded part of the vehicle, the gauge automatically goes to fuel. Does anybody out there have an idea of whats happening?
  2. chopper99
    chopper99
    Was your car originally positive ground?
  3. vintagered13
    vintagered13
    Have no idea. It's a 46 chevy stylemaster. I don't know which years fell under positive grounds. How would I fix the problem if it was?
  4. vintagered13
    vintagered13
    I know it used to be a 6 volt system, but now I have a new harness and a sbc in it. So it's running 12 volts. I had to get plastic parking light sockets, cause the charge would keep blowing fuses when they ground out.
  5. Big T
    Big T
    from Florida
    No, the car should have originally been a negative ground. GMCs had positive ground on their 6 volt setups.
  6. vintagered13
    vintagered13
    Does anyone else have this problem or is my lack of electrical knowledge that should be examined. It's a summit 18 circuit Universal wring harness.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Did you wire in a voltage drop to the gauge? HRP
  8. vintagered13
    vintagered13
    Yep, have the 12v source to the voltage drop and voltage drop to the gauge, and the sender wired to the gauge.
  9. hotrodjohnny77
    hotrodjohnny77
    Bad sending unit? See it all the time.
    Jon
  10. KJSR
    KJSR
    from Utah
    It sounds like you are completing the circuit by intalling (grounding) the gauge and it sounds like you may have a bad sending unit. Does it still do it if you remove the wire from the sending unit? On a properly working gauge you can remove the wire from the sender, ground it, and it will read full. If the sender is ok you may have a short somewhere in that wire.
  11. vintagered13
    vintagered13
    The funny thing about it is When I hook up the sender wire, and the 12v source to the gauge then place it int he dash the lights in the unit glow slightly. but the dash lights are not turned on. To me it sounds like I've got a positive wire charging the dash, but I've been over them and I can't find anything.
  12. vintagered13
    vintagered13
    Oh and the gauge does it without the sender hooked up. From empty to full, as soon as I place it in the dash.
  13. KJSR
    KJSR
    from Utah
    Does the post for the sender wire go through the housing for the gauge? Is there any isolator washers or bushings missing? Check the cont between the post and the gauge body. I think if you have cont the unit is grounding internally.
  14. vintagered13
    vintagered13
    The post does go through the housing for the gauge! I know for a fact there is no isolator washers on it. I'll be sure to add some and see if that works.
  15. KJSR
    KJSR
    from Utah
    Try a piece of rubber tubing or heatshrink around the post to protect it.....
  16. vintagered13
    vintagered13
    Good idea, thanks for the advice
  17. HOTRODPRIMER
    HOTRODPRIMER
    Do you have a ground wire from the sender to the frame? HRP
  18. primed55
    primed55
    Also make sure the new sending is the same ohm's as the orginal?
  19. KJSR
    KJSR
    from Utah
    Well- did the post contacting fix solve your issue? Don't leave us in the dark....
  20. Big Tony
    Big Tony
    Long shot but it happened to me... Check your wires going through the fire wall. I had a wire (new) that got a cut in it and was causing a similar problem. Damn i hate electrical problems..good luck
  21. rayford
    rayford
    from calhoun ga
    check your sending unit wire it might be touching the body i know it happened to me
  22. valkokir
    valkokir
    from DeKalb, IL
    Most have been stated but this is from the troubleshooting section of my fuel sender:
    TROUBLE SHOOTING HINTS
    SYMPTOM: Meter pointer stays above FULL mark when the Ignition switch is turned on.
    1) Full tank of Gas.
    2) Water in fuel tank.
    3) SEND and NEG wires reversed on Sending Unit.
    4) Meter not grounded properly.
    5) SEND wire is touching NEG terminal or wiring
    6) Center rod on fuel units touching the outside tube.
    7) Unit not calibrated.
    Note this is for a resistance type sending unit, not a float(which explains #2 & #6 if you were wondering).
    http://livorsi.com/pdf/GSFLC3-GSWLC3.pdf
  23. 325w
    325w
    Make sure your sill plate screws are not pinching the wire for the sender.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Dammit man!,,did you ever figure out what the problem is/was,,,,you could at least tell us! HRP
  25. skidsteer
    skidsteer
    ditto what KJSR said. I had the same thing happen to my temp and oil pressure gauges, but ONLY when I tightened the mounting nuts to the back of the dash, worked fine when not mounted in the dash!!??!! This happened with brand new harness, brand new gauges. Insulated the metal mounting bracket on the gauge cluster, so it would not touch the metal dashboard, now I'm a happy guy.
  26. vintagered13
    vintagered13
    alright, finally got the dash back into place. After getting some sound advice from all the fellow Hambers I went ahead and took the panel off and found that the post in the back did not have isolator washers attached. So I went ahead and placed some on the posts, reconnected the wires and took KJSR's advice with the shrink wrap. It looks like we have a winner! The gauge is reading the correct amount. So now I just have to run it for a while and see if the fuel level goes down. Hopefully this weekend.
    Thanks again guys, and skidsteer, how did you insulate the mounting bracket?
  27. adamabomb76
    adamabomb76
    from York, Pa
    Here is my issue. I have a '48 Chevy, but the entire driveline is an S-10 of some sort except the motor. All 12V new harness. I am still sorting ground issues out and other electrical ****. So anyway. I am running an S-10 Blazer tank in a pick-up frame. (some say HUH who cares!) The after market senders are so close to the floor in the back that they scratched through enough paint to bridge. Check all your posts, and connections. I hate electrical.
  28. vintagered13
    vintagered13
    I hate electrical also. Everything needs to be just right. It's double ****ty when your in a garage and it's 90º out under a car, fiddling with wiring. Nothing says rage like that.
  29. KJSR
    KJSR
    from Utah
    Glad to hear it worked out for you!
