What does this Intake fit?? ? Help!!!!
Discussion in 'The Hokey Ass Message Board' started by SAVAGE, Apr 3, 2004.
  1. SAVAGE
    SAVAGE
    Alliance Vendor
    I picked up this intake site unseen. I don't know what engine it fits.
    Maybe someone out there knows . Its an old Edelbrock and only says ML
  2. SAVAGE
    SAVAGE
    Alliance Vendor
    nuther shot
  3. SAVAGE
    SAVAGE
    Alliance Vendor
    top view
  4. SAVAGE
    SAVAGE
    Alliance Vendor
  5. SAVAGE
    SAVAGE
    Alliance Vendor
  6. Paul
    Paul
    Editor
    sure looks like Chevy to me..
    Paul
  7. SAVAGE
    SAVAGE
    Alliance Vendor
    what is the tube out the back of it?? Its wierd. Is it biig block maybe??
  8. SAVAGE
    SAVAGE
    Alliance Vendor
    just put it up to mu small block chevy intake. its like 2 inches longer.. Is it olds?? also check out how big the distributor hole is. Chevys all have a small hole!!!
  9. SAVAGE
    SAVAGE
    Alliance Vendor
    here it in next to a small chevy intake
  10. Andy
    Andy
    Don't know the difference, but it is a 348 or 409 Chevy intake. Maybe both. Nice find! [​IMG]
  11. SAVAGE
    SAVAGE
    Alliance Vendor
    that is kind of what i was thinking.. Do you know for sure?? Or do you think it could be something else.????
  12. Andy
    Andy
    I am sure it is big block Chevy. I am reasonably sure it is 409. It could be 396 but extreamly unlikely. Match it up to a gasket for a 396. If it does not fit, then it's a 409.
  13. tomslik
    tomslik
    348/409,reg BBC's had seperate ports
  14. Anderson
    Anderson
    I'd give you $1,000 if it was for a small block olds...but olds is a lot wider, big block olds even more so.
  15. SAVAGE
    SAVAGE
    Alliance Vendor
    this one is for an early olds. its really cool because it has changed color so much it looks like magnesium..
  16. draggin'GTO
    draggin'GTO
    [ QUOTE ]
    [/ QUOTE ]
    Could be 366/396/402/454 BBC. The intake ports are not separate, just the exhaust ports are. The bolt hole above the center of the two intake ports looks the same as the 402 in my '70 Chevy C20.
  17. Mutt
    Mutt
    Edelbrock used the initials from the motor it fits for a manifold's model designation - I would guess ML would be a Mercury/Lincoln. IIRC Lincoln/Mercury shared motor size in the early 60's.
    Mutt
  18. williebill
    williebill
    Mutt is probably right if the ML is factory.My Buick 6 deuces Edelbrock is a B58,the 2X4 Buick is a B262.
  19. SAVAGE
    SAVAGE
    Alliance Vendor
    well my other intake says ML and it is Olds I asked Edelberock about it . the part number id OE6L ML It is pictured above also. Aaron SAVAGE
    i have a couple of Weiand intakes Caddy ones says CD393 and the chrylser is WC6l and WC8L for the logs WD6 for the Desoto logs. This one really baffles me though
  20. tomslik
    tomslik
    draggin', you are correct.
    i was having a brain fart...
  21. tomslik
    tomslik
    ports dont't look right for a bbc, the center of the ports have a bolt hole and the only rectangular port bbc heads were huge...
    everything else bbc was oval port.
    my $$ is still on 348/409..
  22. Germ
    Germ
    aaron you have any caddy INTAKES? 331? looking for a 2x4. DETROIT RACING it's called,,,,
    HAHAHAH
    CHRIS wake UP....BLEH BLEH BLEH
    germ
  23. SAVAGE
    SAVAGE
    Alliance Vendor
    just got done taking a piss on this one. It may be spoken for though. . I paid alot for it for a friend and now he hasn't sent me the money for it..
  24. silent rick
    silent rick
    not to get picky, but wd6 is a dodge, wds6 would be for a desoto.
    i have a wo6, a weiand drag star for a 303/324 rocket that i might let go. also pontiac and dodge drag stars too.
  25. Paul
    Paul
    Editor
    someone on ebay thinks this one fits the 348-409 ebay 6x2
  26. SAVAGE
    SAVAGE
    Alliance Vendor
    sorry you are right rick. I remembered wrong the desoto is wds6. I really think this is 348 409 I found an image of a 2x4 intake for a 348 409 and it looks the same and the one on ebay is the same.. I would be interested in your drag star for the dodge. My buddie is putting a dodge in his coupe. Let me know Aaron SAVAGE
  27. tommy
    tommy
    It looks like a 348/409 with an open plenum eliminating the port dividers. Heres one with that bolt hole at the top of the intake ports.
  28. Is the road draft tube in the block or the intake on the chevy's?
  29. Mutt
    Mutt
    [ QUOTE ]
    [/ QUOTE ]
    You're right - it appears to be the same manifold. It looks like the C68 model number was polished off of this one.
    Mutt
  30. getinolder
    getinolder
    from Minnesota
    Hi, I stumbled on this thread looking for info on a OE6L ML intake. Savage could you tell me what size Olds this is for? I was thinkin 394. Also what woul this be worth?
