Homemade Slingshot Intake
Discussion in 'The Hokey Ass Message Board' started by Grudge, Jul 20, 2008.
  1. Grudge
    Grudge
    Thought I'd share my version of making a slingshot intake on the cheap. There was a great tech article a while back (can't find it now) that inspired me to make my own.
    Let me start by saying that I would much prefer having a real cast-aluminum dual-carb job, but money's a little tight right now. Besides, keeps me off the street:D
    I started with the flanges, making a template out of paper, and transferring the pattern into my solid modeling software so I could make a .dxf file for the laser cutter. Let me know if any of you would like a copy of the file. The tubing (1-1/4" mild steel, 1.8" radius mandrel bend) came from a highly recommended outfit here in Oregon called Columbia River Mandrel. Their website has tons of great stuff, the shipping was fast, can't say enough good things about it.
    [​IMG][​IMG][​IMG]I split the 180 degree pipes using a tubing cutter, and then ground the inside lip.
    Next, using the tooling marks from the bender, I taped cut lines on each pipe.
    Using my handy dandy chop saw, I was left with four individual pipes.
    Next I split the center tubes using my cutoff wheel.
    After much welding and grinding, it's starting to come together.
    And finally with the flanges on, and the glamour shot, with paint.
  2. Jay Rush
    Jay Rush
    looks good man what kind of paint did you use on that
  3. Grudge
    Grudge
    Thanks. It's Duplicolor cast-iron-color engine paint.
  4. adamabomb76
    adamabomb76
    from York, Pa
    Sweet!! Now you even have the chunks of exhaust tubing left to throw in the road box incase you need a roadside rad. hose repair. Very nice intake man.
  5. btbsandman
    btbsandman
    Fricking awsome...
  6. Jethro
    Jethro
    Nice work!.... A different take on the slingshot, I like it too!
  7. speedtool
    speedtool
    You're an awesome possum, man! Good work.
  8. strombergs97
    strombergs97
    I like it..Great work..I'll take one. I have a single intake and two Stromberg 97s. I would like to build one..
    Duane.
  9. Carb-Otto
    Carb-Otto
    from FINkLAND
    That looks good!
  10. Flat Ernie
    Flat Ernie
    Tech Editor
    You might do well selling those flanges...I think there'd be a small niche market for them
  11. FEDER
    FEDER
    Great Job!!!! That really looks cool!!
  12. Grudge
    Grudge
    Hmmmm...What do you think, any takers out there? I can have some more made up.
  13. NortonG
    NortonG
    Looks good.
    Any pictures of it mounted on the engine?
    Norton
  14. great job man!!
  15. Nitrofan
    Nitrofan
    from Kentucky
    That is some nice handy work!
  16. How does that compare price wise, bearing in mind that a cast Tardel slingshot is $65?
  17. Rusty Karz
    Rusty Karz
    As someone said in another thread: "You are only limited by your imagination". Nice work.
  18. the-rodster
    the-rodster
    Great work!
    But the cast piece is only $65, you gotta have close to that in the bends and flanges.
    Rich
  19. Grudge
    Grudge
    You guys are right, the Tardel is a nice little manifold, especially for the price. I come in slightly under $60, but that's only because of my source for laser cutting.
    I can't make a case for doing this based on economics it's true. I seem to have this bad habit of not knowing any better:D
    I built this partly because of money (not having mutch) and partly to continue teaching myself how to fabricate cool stuff out of metal.
    Thanks for all the compliments guys, I appreciate it.
  20. Chebby belair
    Chebby belair
    from Australia
    Great stuff, love the fab. Keep it up
  21. liljgoneman
    liljgoneman
    will ya make one for a poly motor?......
  22. InjectorTim
    InjectorTim
  23. Dago 88
    Dago 88
    But, there is alot of pride in doing somthing like that yourself & I think that's what hotrodding is all about. Very nice work.:cool:
    Cheers Dago.
  24. I actually like the looks of this one BETTER then Tardels IMHO,,,plus the satisfaction of making it. Grudge, check your PMs please.
  25. FencePost
    FencePost
    BINGO...no 1-800- intake here. GREAT job
  26. dickster27
    dickster27
    from Texas
    Grudge, if you decide to market these you can put me on your list.
  27. AHotRod
    AHotRod
    Very nicely done.
  28. plym49
    plym49
    from Earth
    Why buy when you can build, create? That's what it is all about. Anyone can buy a part, you gotta respect someone who makes it (and who uses creativity for design and who repurposes something entirely different).
    Nice job, nice workmanship: this is really really nice.
