How The H.A.M.B has inspired Me....Pics
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Jul 23, 2008.
  1. Bonehead II
    Bonehead II
    A thanks to all that have gave me the inspiration in the past year, '29 ford turdor, cut 20" from side window. 4" from the top. 292ci. engine with a six pack,T-5 trans. QC rear end. Home made frame
  2. hrm2k
    hrm2k
    Sweet !!! but I think it needs wires on the front...the solid wheels don't do it for me !
  3. Toqwik
    Toqwik
    Looks good, well thought out but I bet that ride will **** with those fronts !!!
  4. Harrison
    Harrison
    Neat car. Don't wait a year to post update pics.
    Do you plan to lengthen the pitman arm?
    JH
  5. its bad enough i spewed coke out my nose , but once again have trashed the old womans computer!!:D
  6. Rough Stock
    Rough Stock
    from Austin, Tx
    wow... that's not even old skool... neanderthal skool
  7. Lee Martin
    Lee Martin
  8. Looks cool. But I think you are going to have troubles with the front spring mounted to hairpins like you have them. When the suspension is working it will be twisting the hairpins. The front steering and suspension is going to feel mushy.
    Never seen it done and I think it is really un-safe.
  9. Also you have the hairpin mounted in single sheer and really, really to far of the frame. They are most likely going to fail or just plain old rip off.
  10. Aaron51chevy
    Aaron51chevy
    Neat car, but I agree those hair pins are waaay to far away from the frame. In a perfect world they would meet at the vehicle centerline, just like Henry designed. Since we split the bones, or hair pins, you want them as close to the frame as possible. That tube holding the hairpin bolt is going to have M***IVE stress in it.
    I can't make out the front axle attachment but there was a post a month or so ago about the subject of mounts welded to bones breaking.
  11. evilone0528
    evilone0528
    right click.......save as!
    Great looking start!
    EVIL
  12. Dog_Patch
    Dog_Patch
    That's a sweet looking ride. Can I ask where you got your quick change?
  13. diggin it...I agree on the wishbones being too far away...gonna be bad*** when it's done...though I don't advise running the bias plywood on the front
  14. ChrisMejia
    ChrisMejia
    HA HA HA HA HA HA! Oh man! I couldn't resist on quoting this comment. You killed me rufstoksilver!
  15. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I like it!
    save the side pieces you cut out for a stretch limo sedan!
  16. fiftyv8
    fiftyv8
    from CO & WA
    I am with jrblack30 on your front end and I dont even like the front spring mount to the hairpins. There is going to be a lot going on in that suspension that could let go.
    <TABLE cl***=tborder id=post2981825 cellSpacing=0 cellPadding=6 width="100&#37;" align=center border=0><TBODY><TR><TD cl***=thead style="BORDER-RIGHT: #e5e5e5 0px solid; BORDER-TOP: #e5e5e5 1px solid; FONT-WEIGHT: normal; BORDER-LEFT: #e5e5e5 1px solid; BORDER-BOTTOM: #e5e5e5 1px solid"><!-- status icon and date --> <!-- / status icon and date --></TD><TD cl***=thead style="BORDER-RIGHT: #e5e5e5 1px solid; BORDER-TOP: #e5e5e5 1px solid; FONT-WEIGHT: normal; BORDER-LEFT: #e5e5e5 0px solid; BORDER-BOTTOM: #e5e5e5 1px solid" align=right> </TD></TR><TR vAlign=top><TD cl***=alt2 style="BORDER-RIGHT: #e5e5e5 1px solid; BORDER-TOP: #e5e5e5 0px solid; BORDER-LEFT: #e5e5e5 1px solid; BORDER-BOTTOM: #e5e5e5 0px solid" width=175></TD></TR></TBODY></TABLE>
  17. I SMELL SMOKE
    I SMELL SMOKE
    i like the motor mounts
  18. oldbike
    oldbike
    Regarding the front tires. Are they made by Firewood, Woodyear or Oakohama? Do you decide when to replace them by counting the remaining rings instead of looking at wear indicators. By the way, very nice car
  19. :mad: so yer the sumb!tch that stole the wheels off my chariot then?... i want them back.
    J/K... interesting ride... kind of a modified meets a vicky looking thang... and i dig the tri-power. is that going to be the final roof height?
  20. GREASEMONKEY72
    GREASEMONKEY72
    thats a *****in car man, i like it
  21. Muttley
    Muttley
    Comedy^^^^
  22. kustombypook
    kustombypook
    Talk about pizza cutter tires. Sorry, I had to get one in too.
  23. Bonehead II
    Bonehead II
    Ok OK Don't you guys know that most Canadians run that type of wheel, there hard to find Ha Ha Ha
  24. Bonehead II
    Bonehead II
    Thanks for the advice, I will go back to the drawing board.
  25. Bonehead II
    Bonehead II
    Can someone come up with with a drawing of a bracket that will work on thoses hairpins it would be much appreciate.
  26. HotRodMicky
    HotRodMicky
    I suggest to redesign the rear suspension ....
    Search on here for binding suspension
  27. I think that you cannot do what you are thinking with radius rods. Best bet is leave the axle where it is and find and use some Ford radius rods. They are strong enough to run a set up simular to what you are doing.
    I am not trying to rip your design apart. I like radius rods and suicide suspensions, just not the way you have yours set up now. Run Radius rods and mount the spring to them, a lot of guys are doing it that way.
    For the rear end comment someone posted. You will see some binding. To fix that just use articulating spring hangers, Posies has them I think.
  28. Unkl Ian
    Unkl Ian
    Fancy spring hangers won't fix the bind
    caused by parallel split bones on back.
  29. HomemadeHardtop57
    HomemadeHardtop57
    way to go..the section job is killer..it takes a pair of balls to do something like that
  30. Bonehead II
    Bonehead II
    Thanks guys...I was going to get a rear spring made to fit. as far as having ball to cut it up , ask the wife she had them for years..Ha Ha Ha
