Hot Rods Banger Powered Cars - Post your pics here
Discussion in 'The Hokey Ass Message Board' started by Greg Stokes, Jul 23, 2008.
  1. There is so much interest in banger motors here I thought it would be great to have one post where we can post our banger powered cars.
    Be it full bodied cars or race cars - as long as its banger powered - lets put it all here.
    Its sometimes hard to keep up with who has what, looking forward to seeing what you guys post on this thread. I will start with mine:
    Project 29
    29 Model A closed cab pick up
    A motor, Thomas twin intake, Mallory ignition, Hallock exhaust manifold, Winfield head and cam
    T5 on owner adapted bell housing
    Dropped I beam and Ford V8 rear end on torsion bar suspension
  2. HotrodVon
    HotrodVon
    Wow- great looking pick-me-up!
    Is it a flathead banger or ?
    Can you show a pic of the engine?
    Keven
  3. HotrodVon
    HotrodVon
    Bonneville bound banger car.
    Keven
  4. Chris
    Chris
    Mine:
    My brother's:
    My Dad's:
    BANGERS UNITE :D
    Dannerr likes this.
  5. Corn coupe
    Corn coupe
    from CZ
  6. C4 Metal Werks
    C4 Metal Werks
    Great looking rods!!!!!
  7. Retroline
    Retroline
    My ****ter
    Dannerr and ROCKER77 like this.
  8. Great Tudor..... Retroline (was about to call you skippy :eek:)
    Can Chev overheads play?
  9. Retroline
    Retroline
    Go on Jimmy put up some pics, is it moving ahead?
    I want to see that one done.
    And, hey, I 've been called worse.;)
  10. Ice man
    Ice man
    She runs a warmed up B/5 SP and is used everday, almost
    Dannerr likes this.
  11. It is progressing
    Chev roadster '25 Chev 4 with 3-port
    Dannerr likes this.
  12. denis4x4
    denis4x4
    from Colorado
    '31 Model A with inserts, cam, headers, V-8 clutch, 39 ******, new 97, B-F 7.5:1 Super head. These are older photos as interior is now leather and tires are Coker/Hurst dirt trackers.
    Dannerr likes this.
  13. phlip
    phlip
    Heres Mine...
    Dannerr likes this.
  14. wlspdshop
    wlspdshop
    from Missouri
    Phlip.....that is just beautiful!!
  15. Jalopy Banger
    Jalopy Banger
    from Sweden
    This is a pics of my -30 coupe. Winfield alu head, 2x Ford/Holley 92's, G28 distributor, Riley intake and headers.
      100.3 KB
    Dannerr likes this.
  16. kornbinder
    kornbinder
    from Sonora, CA
    Here's mine
    Dannerr likes this.
  17. Heres a couple The flathead is 6 volts, has a 4 9/16 stroker crank, Brierely/ Winfield SU1A cam, 1.75 intakes, approx 8.5 to 1 compression, full inserts, new model"A" inserted rods, modified V8 oil pump, 18 lb Al fly- wheel, pistons are J&E with corrected compression height. modified model "B" distributor, single "BB" downdraft.
    The 2 port is an original head, stamped 4 8 30, has Taylor rods, full inserts, carbs are "BB"'s, cam supplied by Taylor, J&E pistons, compression height corrected to 7 3/4 to one, fully inserted "C" crank, 12 1/2 Al flathead V8 flywheel, 10" clutch, FS ignition.
    Has run an 8.7 at 66 hill climb The car was built in 90 days in 1997, has a "B" front axle,
    "A" Halibrand quick change 38 lincoln side shift with ford gears, 40 brakes, fuel tank is WW2 surplus, body narrowed 6 inches, previous owner said it had been on an early circle racer in AZ it had been channeled 3", we raised it back to stock, frame is from a "T" bucket kit, bought at a yard sale for $75.
    Dannerr likes this.
  18. 29bowtie
    29bowtie
    Looking great Jimmy,that's one of my favorite projects on the HAMB.:D
  19. 5wbomber
    5wbomber
    Was banger powered till last week, now she's 21 studder, dropped axle,and juicers!!! :)[​IMG]
    Dannerr likes this.
  20. Jersey Joe 67
    Jersey Joe 67
    from J Town
    ON IT'S WAY TO BEING "BANGED"
  21. Some great looking rides guys!
    Keep em coming!
  22. Artiki
    Artiki
    from Brum...
    My two. Both bangers but very different.
  23. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Mine. Sports Coupe Turned Roadster. Lots of Metal work done. Currently she is at the final blocking stage to be ready for paint.
    Dannerr likes this.
  24. Crazydaddyo
    Crazydaddyo
  25. [​IMG]
    Mine's a Ford Model B, with and OHV Miller Hi-Speed Head. 12 to 1 Compression ratio. Stromberg 97 carburetors. Full pressure oil. with separate filter and oil pump. Counterbalanced five main crank. The photo was taken seven years ago at Monterey. Since then, I've added a 32-35 Ford front axle; and 17 inch Dayton knockoff wheels. Plenty of photos elsewhere on this site. :)
    Dannerr likes this.
  26. any more pics with your log on the top? that is a righteous picture!
  27. Fur Biscuit, here are some more pics - engine, front torsion arm and surfboard on top etc
    Dannerr likes this.
  28. 4 2 GO
    4 2 GO
    This engine looks a bit cluttered but has crossed Australia three times. B block, counterbalanced crank, Lion Speed Head, Weber 32-36 carb, 34 four-cylinder ****** with 40 gears, Mitchell Overdrive, Datralley cam. Runs at 60 mph all day, over 400 miles in a day, in 100 degree heat.
  29. Elrod
    Elrod
    Dual 81's
    Driving
    And now with dual exhaust!
  30. the ex-
    Dannerr likes this.
