49-53 flattie camshaft question
Discussion in 'The Hokey Ass Message Board' started by demon452, Jul 29, 2008.
  1. demon452
    demon452
    from Michigan
    Ok i know there are alot of post on the subject but here it goes. I have a 40 ford truck fenderless so it's pretty light. My engine is a 50 8ba .030, stock stroke, and a valve job. I do have a set of stock heads (8ba) and a set of edlebrock aluminum 1's, also a 378 rear gear and a t-5 trans. I also have a 3 pot fenton intake and a 2 pot fenton intake w/holley 94's. I am looking for a camshaft that gives good power and has some lope to it. I am also going to run open headers and a pertronix distributor conversion. So what type of camshaft and or should i use stock heads and get them milled. Any suggestions are apperciated
  2. demon452
    demon452
    from Michigan
    Forgot to mention i also have an aluminum flywheel, also what is the max lift stock heads (8ba) can handle and how much difference in cooling between aluminum heads. Thanks again
  3. Ol Blue
    Ol Blue
    from In
  4. Pete1
    Pete1
    from Wa.
    A 1007B is what you want.
    An L100 is a good cam but WAY too much for your essentially stock cubic inches and heads. If you have a set of alum. heads, they would give more performance than milled stock heads. They will cool better too. The 2 pot would work better than the 3 for your application.
    Pete
    "Been in the cam business 53 years"
  5. Flat Ernie
    Flat Ernie
    Tech Editor
