Lathe operators? steel wheel question...
Discussion in 'The Hokey Ass Message Board' started by thunderbirdesq, Jul 29, 2008.
  1. thunderbirdesq
    thunderbirdesq
    After months of searching for nice 16" steelies with a 4.5" bolt pattern to match my rear axle, I finally scored a few pairs of 49 ford wheels that my favorite junkyard owner had been hoarding in his barn. I ordered new 750x16 firestones and mounted them up on my newly blasted and painted wheels. Went out to mount them today and the %#* center hole is too damn small for the wheel to seat! Doh! What a dumb***, I didn't even check that! Now, I don't want to run spacers as those thin cheapies make me nervous and the thicker type that bolt on would sit my wheels out another inch. I thought about redrilling the axles and drums and just running the 40's wheels I have, but after measuring it, there's just not enough meat there to do so. Is it possible to mount a steel wheel in a lathe to turn the id of the center opening of the wheel out larger to match the hub? The hub is 2.75" and the wheel looks like about 2.50", maybe a bit bigger. Anyone ever do this?
  2. 37RAT
    37RAT
    from Wisconsin
    Probably the easiet thing to do would be to mill it out on a Bridgeport or similar milling machine. Thats how i did mine, without the tire mounted, of course. Good luck.
  3. Unkl Ian
    Unkl Ian
    Possible,if you can find access to a lathe that big.
    Another way would be on a milling machine with a boring head.
    Of course,you will lose the lip around the hole.
  4. Buford
    Buford
    That would be easy...if you had a lathe big enough. Frank
  5. Look at heavy equiptment shops. Lots of us here have had big work done at the local gravel companies Machine shop.
  6. Henry J
    Henry J
    If you can't chuck up the axle and turn down the center....just do like the others said, put them on a Bridgeport indicate the center and use a boring head to bore the center hole out. If its that close split the difference between the two....no big deal!
  7. thunderbirdesq
    thunderbirdesq
    Thanks guys, Yeah, I guess finding a lathe that's big enough is the real question!:D I hadn't thought of a milling machine though, that's probably the ticket there. unkl ian, I thought about the loss of that lip and the integrity of the wheel without it, but the front wheels are not hubcentric I don't think it will make a difference in this case.
  8. Glen
    Glen
    An old school machine shop with a rotary table would work.
    If all else fails check with the DUB crowd in your town.....Wheel Spe******ts here in Phoenix has a lathe that they mount 24" wheels on.
  9. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    No problem.. We use a mill with a boring head... My lathe is just a hair to small... Jason
  10. toddc
    toddc
    Probably easier to turn down the shoulder on your hub or axle.
  11. Horan
    Horan
    thats it
  12. Get a round grinding stone that goes in an angle grinder and you'll be done pretty quickly. You should be able to make a clean circle if you take your time. Finish off with a big half round file.
  13. dirt t
    dirt t
    Why not turn down the axels?? Small lath??
  14. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Just find a lathe. We do it all the time
  15. thunderbirdesq
    thunderbirdesq
    Now I had this thought too, Kev. Not just because I'm a cheap-***, but also because I just moved to the Buffalo area and I really don't know the area or anyone well enough to ask for favors (yet..:D) or know who'll do this and won't charge me a left nut for it... which I guess goes back to me just being a cheap-***!:D I measured with dial calipers today instead of the ****py tape and it only needs be opened up about 0.125" total. I'm gonna get a round stone and get a grindin'! Thanks again guys.
